Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
How to troubleshoot amana refridgerator
I have an amana refridgerator that has stopped cooling.  Still sounds like the motor is running. What are my first steps to test it before curbing it?
  • Anonymous Dec 29, 2007
    sounds like my De-frost is stuck on center post bettween frig and freezer very hot not frezing
  • Anonymous Mar 07, 2008
    MY REFRIGERATOR IS TOO WARM AND MY FREEZER IS DEVELOPING FROST ON THE BACK PANNEL
  • 58 Answers
The evap fan, fan by compressor and the compressor should all be running. if they are then more than likely a bad compressor, so junk it
Posted on Oct 31, 2007
Why amana fridge ABB1924WES freezer works refridgerator doesn't?
Check for a failed evaporator (cooling coil) fan motor or iced up evaporator due to a failure in the defrost timer, thermostat, or heater.
Jul 26, 2014 | Amana ABB1924WES 19 bottom mount...
AMANA gas dryer runs only a few minutes then stops
Sounds like your motor is weak after its cools down does it start again then the same thing happens?
May 01, 2014 | Amana ALG331RAW Gas Dryer
My Amana refridgerator does not cool but the freezer works
If you have noticed a rise in temperature in the fridge, and there seems to be fromst building up in the freezer than your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Sep 07, 2012 | Amana Refrigerators
Everything is out, we have it off, no water is draining. The freezer just stopped cooling, hence the refridgerator side stopped too. I just turned it on after 5 hours. The motor is running and so is the...
Could be that your self defrost mechanism is not working and unit is freezing up and not cooling. Till fixed just defrost overnight and turn on next day. It will run fine for a few days till it freezes up again.
Probably need to replace open heater element. Go to sears web site for part number and then purchase it for less money on ebay.
Sep 18, 2017 | Amana Side-By-Side Refrigerator 26 cu. ft....
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
Jul 22, 2011 | Amana Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
I have an Amana bottom freezer fridge model ARB2517CSR the freezer stopped working I cleaned the coils and the fan was working and the fridge was making a buzzing sound. The sound stopped, so did the...
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Jul 03, 2008 | Stainless Cruise 49 Marine Refridgerator -...
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
Refridgerator not cool enough.
sounds like the probable cause is defrost heater. get someone to test the element.
May 27, 2007 | Amana ABB1927DE Bottom Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
290 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
