Question about 1998-2004 MERCEDES SLK230 SLK 230 CARBON FIBER VINYL WRAP SHEET / FILM 60 X 60 5FT X 5FT 1999 2000 2001 2002 2003 98 99 00 01 02 03 04 MERCEDES-BENZ R170
How to remove instrument cluster panel - 1998-2004 MERCEDES SLK230 SLK 230 CARBON FIBER VINYL WRAP SHEET / FILM 60 X 60 5FT X 5FT 1999 2000 2001 2002 2003 98 99 00 01 02 03 04 MERCEDES-BENZ R170
How to remove a dash cluster 94 toyota camry
Remove the 2 screws from the center cluster lower finish panel and remove the center cluster lower finish panel.
Remove the 4 screws from the lower edge of the instrument cluster finish panel.
Using a screwdriver, carefully pry rearward on the instrument cluster finish panel to release the clips and remove the instrument cluster finish panel.
Remove the 4 screws from the instrument panel cluster carrier. Disconnect the electrical connector and remove instrument cluster.
Reverse procedure to install.
Oct 09, 2011 | 1994 Toyota Camry
Can you replace the lights behind the instrument panel? the entire right side of my dash is no longer lit up
Sure Can
Buy bulb number 161
Instrument Cluster Finish Panel
Removal and Installation
1. Remove three screws along the bottom of instrument panel steering column cover (04459). Pull on instrument panel steering column cover to unsnap the three clips across the top of the instrument panel steering column cover. Remove the lower instrument panel steering column cover.
2. Remove four screws retaining the steering column shrouds (3530) together and remove the steering column shrouds.
3. Remove the three screws retaining the bottom of the cluster instrument panel finish panel (044D70).
4. Remove two screws retaining the cluster instrument panel finish panel above the instrument cluster face.
5. Pull cluster instrument panel finish panel to unsnap one retaining clip above the LH A/C register (19893).
6. Pull cluster instrument panel finish panel to unsnap three retaining clips on the RH side vertical edge.
7. Pull cluster instrument panel finish panel away from instrument panel (04320) far enough to disconnect the wiring connector(s).
8. To install, reverse Removal procedure.
I've never done #2, and #1 refers to the panel below the steering column. To remove it completely, pull it towards the driver's seat. There may be retaining clasps on it also.
May 25, 2011 | 1996 Ford Thunderbird LX
My Dash Isnt working, the gauges dont move or work how do i fix it
Instrument Cluster -it could be a loose connection at the harness. REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Disable the SIR system. Refer to procedure outlined in this section.
  3. Remove the cluster trim plate, as follows. Fig. 1: View of the cluster trim plate (1), instrument panel (2), dimmer switch lead (3), fog lamp switch (4), and mounting screws (5) - Chevrolet Malibu shown 93206g21.gif
    Fig. 2: View of the cluster trim plate screws (1), cluster trim plate (2), and instrument panel assembly (3) - Oldsmobile Cutlass shown 93206g22.gif
    1. Remove the bezel from the ignition switch. Fig. 3: Remove the bezel from the ignition switch 93206p24.jpg
    2. Remove the screws fastening the cluster trim plate.
    3. Gently pry out the trim plate.
    4. Detach the hazard and instrument panel electrical connectors and remove the trim plate.
  4. Remove the four screws attaching the instrument cluster to the dash panel.
  5. Pull the cluster rearward and detach the electrical connections, then remove the cluster from the vehicle. Fig. 4: Exploded view of the instrument cluster assembly 93206g23.gif
    To install:
  6. Attach the cluster electrical connectors and position the cluster into the instrument panel recess.
  7. Install the screws into the instrument cluster and dash. Tighten the screws until fully driven, seated, not stripped.
  8. Install the cluster trim plate, using the reverse of the removal procedure.
  9. Enable the SIR system as outlined in this section.
  10. Connect the negative battery cable.
Nov 09, 2010 | 2001 Chevrolet Malibu
Insturmentation panel lights fuse blows when i start car
Try to remove the instrument panel and disconnect the harness to see if doing that gets rid of the blown fuse when starting the car. If it does, then the instrument panel should be replaced with another. If the fuse still blows when starting, then there is a wire shorted to ground somewhere.
Instruments and Switches Instrument Cluster Removal & Installation To Remove:
  1. Remove the instrument cluster trim plate.
  2. Remove the instrument cluster mounting screws.
  3. Rotate the instrument cluster rearward and lift up on the top of the cluster in order to disengage the locating pins.
  4. Disconnect the electrical connectors from the instrument cluster.
  5. Remove the instrument cluster.
To Install:
  1. Connect the electrical connectors to the instrument cluster.
  2. Position the locating pins to the holes in the instrument panel.
  3. Install the instrument cluster by rotating the top inward.
  4. Install the mounting screws.
  5. Install the trim plate.
Nov 09, 2010 | 2001 Pontiac Grand Am SE
How to chnge dash board light
If it's in the cluster, see procedure below for removing cluster. If this isn't what you needed, please get back to me.
1997-00 Buick
CAUTION All models covered by this guide are be equipped with a Supplemental Inflatable Restraint (SIR) system, which uses an air bag. Whenever working near any of the SIR components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SIR, as described in this section.
  1. Disconnect the negative battery cable. Disarm the SIR system, as outlined in this section.
  2. Remove the instrument panel cluster trim plate using the following procedure:
    1. Remove the instrument panel access hole covers from the instrument panel using a small flat-bladed tool.
    2. Remove the screws from each end of the instrument panel cluster trim plate.
    3. Remove the screw(s) from the lower edge of the right side of the trim plate.
    4. Open the instrument panel compartment (glove box) door.
    5. Pull the right lower trim panel plate from the instrument panel.
    6. Pull the steering column tilt lever and tilt the steering column to its lowest position.
    7. Grasp the instrument panel cluster trim plate at the right edge and slowly pull, working to the left to release the retainer clips. Remove the instrument panel cluster trim plate from the vehicle.
Fig. Instrument panel cluster trim plate and related components-1997-00 Buick models
      Fig. Front view of instrument cluster removal and rear view of the wiring harness connectors-1997-00 Buick models
      1. Remove the push-pin retainers from the top of the cluster.
      2. Rotate the instrument cluster rearward and disengage the locating pins on the bottom of the cluster from the instrument panel. Detach the electrical connectors and remove the instrument cluster from the vehicle.
      3. Installation is the reverse of the removal process. Use care to make sure all installation clips are properly located. Do not over-tighten any screws or they could force their way through their holes and the panel will not be held properly. Squeaks and rattles may develop later.
      Oct 18, 2010 | 2000 Buick Century
      Headlight swicht broke
      1. Disconnect the negative battery cable from the battery.
      2. Remove the lower steering column cover-to-instrument panel screws and the cover.
      3. Remove the instrument cluster trim plate-to-instrument cluster screws and the panel, then allow the panel to hang to the left side by the wiring.
      4. Disconnect the electrical connector from the rear of the headlight switch.
      5. Disengage and remove the headlight switch from the instrument cluster trim plate.
      To install:
      1. Connect the electrical connector to the rear of the headlight switch.
      2. Engage and install the headlight switch in the instrument cluster trim plate.
      3. Install the instrument cluster trim plate-to-instrument cluster screws and the panel.
      4. Install the lower steering column cover-to-instrument panel screws and the cover.
      5. Connect the negative battery cable to the battery and check operation.
      Apr 27, 2010 | 1995 Chevrolet Astro
      Need to replace instrument cluster/AC bulbs
      Hello, You can obtain a 2004 Ram Factory Service Manual with all of that information available from Promanuals.net. The reason why it may be so important is because right before the removal instructions the service manual has diagnostic instructions to try. There are numerous pages on removing the instrument cluster, and cluster bezel.
      (1) Disconnect and isolate the battery negative
      cable. (For Airbag)
      (2) Remove the cluster bezel from the instrument
      panel. (Refer to 23 - BODY/INSTRUMENT PANEL/
      CLUSTER BEZEL - REMOVAL).
      (3) Remove the four screws that secure the instrument
      cluster to the instrument panel structural support
      (Fig. 5).
      (4) Pull the instrument cluster rearward far
      enough to access and disconnect the instrument
      panel wire harness connectors for the cluster from
      the connector receptacles on the back of the cluster
      housing.
      (5) Remove the instrument cluster from the instrument
      panel.
      Oct 01, 2009 | 2004 Dodge Ram 1500
      How is the instrument panel removed from the dash of a 97 mercury cougar problem
      1997 Thunderbird/Cougar Instrument Cluster Removal
      1. Disconnect battery ground cable (14301).
      1. Remove retaining screws and instrument panel reinforcement (017A28).
      1. Remove retaining screws and instrument panel lower shield (045G02).
      1. Make sure air bag system is properly disarmed. Remove fasteners holding steering column. Gently lower steering column.
      1. Remove screws holding the instrument panel finish panel (044D70) and gently pry off.
        Instrument Panel Finish Panel
      1. Remove four instrument cluster retaining screws. (Do not remove screws from the instrument cluster main lens (10887) and instrument cluster mask (10890)).
      1. Slide the instrument cluster (10849) to the right of the instrument panel opening and disconnect the instrument panel harness from the back of the instrument cluster.
      1. Remove the instrument cluster from the instrument panel (04320).
      1997 Thunderbird/Cougar Installation
      1. Follow removal procedure in reverse order.
      1. Tighten instrument cluster retaining screws to 2-3 Nm (18-27 lb-in).
      Jun 01, 2009 | 1997 Mercury Cougar XR7
      I need to remove the cover on the gauges on a 2001
      Instrument Cluster Removal and Installation Disconnect the battery ground cable. For additional information, refer to Section 414-01 . Remove the instrument panel center finish panel. Remove the screws. Disconnect the connectors and remove the instrument panel center finish panel. Remove the hood latch release handle. Remove the screws. Lower the hood latch release handle out of the way. Remove the instrument panel steering column cover. Remove the screws. Remove the instrument panel steering column cover. Remove the instrument panel steering column opening cover reinforcement. Remove the four screws. Remove the instrument panel steering column opening cover reinforcement. Position the column gearshift lever in the low position. Partially remove the instrument cluster finish panel. Remove the screws. Position instrument the cluster finish panel to gain access to electrical connectors. Remove instrument the cluster finish panel. Disconnect the connectors. Remove instrument the cluster finish panel. NOTE: Illustration shows steering column removed for clarity. Remove the instrument cluster. Remove the screws. Remove the transmission range indicator and position the cluster forward to disconnect the three electrical connectors on the back. Remove the instrument cluster.
      May 15, 2009 | 2001 Ford Explorer Sport
      1998-2004 MERCEDES SLK230 SLK 230 CARBON FIBER VINYL WRAP SHEET / FILM 60 X 60 5FT X 5FT 1999 2000 2001 2002 2003 98 99 00 01 02 03 04 MERCEDES-BENZ R170 Logo
      16 people viewed this question
      Top Trimworks Vehicle Parts & Accessories Experts
      Tom
      Timllfixit
       AEpittsburgh
      AEpittsburgh
      Are you a Trimworks Vehicle Part and Accessory Expert? Answer questions, earn points and help others
