Question about Amana GMH950704CX 69,000 BTU 95% Gas Furnace, 2 Stage, Multi-Speed,
Pressure switch stuck open - Amana GMH950704CX 69,000 BTU 95% Gas Furnace, 2 Stage, Multi-Speed,
Lg wm2016cw
Check that the pressure switch tube is connected to pressure switch. Check that the water inlet valve is not stuck open. To check start washer, turn washer off, if water continues to flow the valve is stuck open, replace.
Aug 01, 2014 | LG WM1814CW Front Load Washer
Amana Air Command 90 furnace LED light blinks 3 times pause 3 times
TRI-COLOR (DSI LED) DIAGNOSTIC TABLE
No. of Red BLINKS
1 Flame sensed when no flame should be present
Verify the gas valve is operating and shutting down properly. Flame in burner assemble should extinguish promptly at the end of the cycle. Check orifices and gas pressure.
2 BLINKS Pressure switch stuck closed/ inducer error
Pressure switch stuck closed. Check switch function, verify inducer is turning off.
3 BLINKS 1st-stage pressure switch stuck open/inducer error
Check pressure switch function and tubing. Verify inducer is turning on the pulling sufficient vacuum to engage switch.
4 BLINKS Open limit switch Verify continuity through rollout switch circuit.
5 BLINKS Open rollout/open fuse detect Verify continuity through rollout switch circuit, check fuse.
6 BLINKS 1st-stage pressure switch cycle lockout If the first stage pressure switch cycles 5 times (open, closed) during one call for heat from the thermostat the control will lockout.Check pressure switch for fluttering, inconsistent closure or poor vacuum pressure.
7 BLINKS External lockout (retries exceeded) Failure to sense flame is often caused by carbon deposits on the
flame sensor, a disconnected or shorted flame sensor lead or a
poorly grounded furnace. Carbon deposits can be cleaned with
emery cloth. Verify sensor is not contacting the burner and is locatedin a good position to sense flame. Check sensor lead for shortingand verify furnace is grounded properly.
8 BLINKS External lockout (ignition recycles
exceeded where flame is established and then lost)Check items for exceeded retries listed above and verify valve is not dropping out allowing flame to be established and then lost.
9 BLINKS Grounding or Reversed polarity Verify the control and furnace are properly grounded. Check and reverse polarity (primary) if incorrect.
10 BLINKS Module gas valve contacts energized
with no call for heat Verify valve is not receiving voltage from a short. If a valve wiring is correct and condition persists, replace module.
11 BLINKS Limit switch open - possible blower
failure overheating limit Possible blower failure, restricted air flow through appliance or duct work. Verify continuity through limit switch circuit and correct overheating cause.
12 BLINKS Module Ignitor contact failure Fault code indicates the module ignitor contacts are not functioning
properly. Replace module.Solid Module - internal fault condition Module contacts for gas valve not operating or processor fault.
Reset control. if condition persists replace module.
3 double 2nd-stage Pressure Switch Stuck Open/Inducer Error
Check pressure switch function and tubing. Verify inducer.
Nov 11, 2013 | Patton Electric Patton PUH680-U Electric...
Model m1mc 090a bw furnace pressure switch open. inducer motor is pulling .45 w.c . the intake pipe above inducer is only pulling .1 w.c. . checked for venting and intake blockages found non. removed...
did you check the hose from the inducer to the pressure switch? HAVE you unplugged the unit from the wall outlet to reset the board? DO you have a voltmeter? If you do you can run voltage across the switch and if you get 24 volts you are open.
Oct 23, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Hotshot over heating
there r three devices which can cause overheating.
1)-thermastat(stuck in close circuit
2)-pressure switch and or flow switch stuck in close circuit.
3)-fuel solenoid stuck open located at fuel pump
Aug 03, 2013 | PressurePro Pressure-Pro Hot Shot Series...
"switch stuck open"
Pressure switch stuck open , check tubes are on tight not split on the connections to the pressure switch, sound like you will need a new one
Dec 31, 2011 | Dayton Gas Furnace Heater
My Whirlpool Washer model LTE6234DQ5 continues to fill with water through ALL cycles.
There are two possible causes of the water not stopping. First is the water inlet valves stuck in the open position and second is the pressure switch not tripping when the correct water level is reached. Turn off or unplug the machine while it is filling and if the water doesn't stop, the water inlet valve/s is/are indeed stuck in the open position. Replacing the water inlet valve assembly should solve the problem.
But if the water stops, the problem is the pressure switch stuck in the empty position. Disconnect power then raise the console up and hinge it at the rear of the machine to access the pressure switch. It is the part with the small clear hose attached to it. Detach the hose and blow air down into it including the pressure switch itself. Replace the pressure switch if the problem persists.
Jan 03, 2011 | Washing Machines
Pressure switch stuck open. I'm getting three blinks. Is is possible to fix this myself.
Hi, yes you can. The pressure switch is just stuck open causing the unit not to fire up. Find the small inducer motor that should be running, if its not and you have the panel off, you have a switch for the panel to kill the power when you take it off. You will have to tape it down with duct tape to restore power.You will see a clear plastic air tube coming from the motor and goes to this pressure switch. Pressure from the motor is what opens and closes the switch. Unplug it at the motor and blow through it several times. You will hear it click. Do this back and forth and it will break it loose. This will solve the problem. Kill power to reset unit. Start it up and your done. If it continues to do this, get a new pressure switch at a appliance parts house. Let me know the out come and please be kind when you rate me as I know you will. Good Luck,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
May 15, 2010 | Goodman GMS90703BXA Heater
Meaning of rudd furnace trouble codes
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
Dec 12, 2009 | Heating & Cooling
Code 3 - pressure switch stuck open. What do I do
where vent motor is there is usually a hose coming off which oressurizes when vent motor comes on, take hose loose **** or blow in it, take tooth pick and stick in all ports where hose connects (could be clogged) when sucking on hose you shoul hear pressure switch click each time you pull a vacumme, if fan has switch on back of fan as some Goodmans have the vent motor may need to be replaced.
Oct 27, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Furnace code light flashes 3 times /pressure switch stuck open
Check the intake and exhaust plumbing for any obstructions. I had same issue, turned out to be ice in the air intake plumbing on outside of house. This may be the problem. The pressure switch can be tested by pulling hose from purge motor that goes to switch and applying a small amount of suction. The switch should make a clicking sound.
Dec 19, 2008 | Kitchen Appliances - Others
Amana GMH950704CX 69,000 BTU 95% Gas Furnace, 2 Stage, Multi-Speed, Logo
71 people viewed this question
Top Amana Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you an Amana Retail Supply Expert? Answer questions, earn points and help others
