Question about Stiebel Eltron TEMPRA 24 Tankless Water Heater
My reset button keep popping - Stiebel Eltron TEMPRA 24 Tankless Water Heater
Reset button on a o smith keeps tripping
After the high limit trips once, it is no longer calibrated. Replace the upper stat and limit.
Mar 21, 2017 | Water Heaters
Reset button on water heater keeps tripping
Need a new thermostat to keep the unit from tripping
Feb 13, 2013 | Bradford White CF-50-6 50 Gallon - 119,000...
I have a rheem 40 gal electric water heater. The GFI on the tank keeps popping do you know what could be causing this
10-23-12
Your tank has a GFCI circuit breaker?
Maybe you mean ECO reset button located on upper thermostat?
If GFCI circuit breaker is tripping, turn power off, open covers inspect for burned parts, and test elements. Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
If ECO reset button is tripping, then replace both thermostats, and test elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 22, 2012 | Water Heaters
Red reset button keeps popping on 50 gal elec. water heater
Check the wiring to each element for burn ends that indicate a short, And more than likely it would be best to replace the thermostat to be on the safe side. It tripping off for a reason, you may reset it several times and eventually have to replace it.
Nov 04, 2011 | Reliance & 50gal Electric Water Heater
I'M NOT GETTING HOT WATER THE SYSTEM HAS POWER IS THERE A RESET BUTTON OR OL SWITCH ON A RHEEM TALL ELEC UNIT
There is a reset button located behind the top cover plate on the side. Remove four screws to remove cover and carefully spread insulation apart to access element,thermostat, and reset button. It is a small round red button. If you push it in and it stays thens the element should come on. If it pops right back out then you need to look at changing the reset.Thank you.
Mar 29, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Reset button keeps popping. Have reset this 3 times now and it happens at night when no one is using water. This is a model 502 heater with dual elements.
The problem I have encountered in this is the thermostat is going bad and tripping out. Inspect the ends of the elements and make sure ther eare no black ends on the wires showing elements may be shorting out causing thermostat to trip. More than likely change the thermostat out and you should be good to go.
They are not to exspensive and local hardware stores carry them.
Aug 15, 2010 | Reliance & 50gal Electric Water Heater
Can this water heater be reset
Red button on upper thermostat just press it to reset.
Jun 07, 2010 | Reliance & 40 Gal Electric Mobile Home...
Electric hot water heater keeps throwing reset button
You most likely need to replace your thermostat. If your thermostat isn't cutting the supply to the element at the preset temperature, as it is meant to, the unit will keep on heating until the over-temperature cut-out operates. This is what the "reset button" is resetting. You should get an electrician or qualified service bloke to replace it so you dont go hurting yourself.
Mar 03, 2009 | Water Heaters
Stiebel Eltron TEMPRA 24 Tankless Water Heater Logo
Top Stiebel Eltron Water Heaters Experts
chargerhp
chargerhp
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
