Question about Toshiba DPF7XSE
DPF7XSE displays "Loading" and then stops. No menu available. How to solve this problem ? The problem began when a Sandisk 3g Cruzer memory stick was inserted. Any suggestions are welcome!
THE PC NOT RECOGNIZE THE REMOUVABLE MEMORY STICK
try removing and reinsterting the memory stick.if still you seem to have a problem then dont worry just install the driver for the memory stick.you can dind the driver in the sandisk website and is available for free download.
May 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
The memory stick pcb has fractured into two pieces
The cruzer does not need the case to work, just be careful how u handle it connect to your computer and get your data. hope this helps
Jun 13, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 8gb cruzer filling itself up???
see if this happens on other computers. If on other computers you have malware on the device itself. If only on one computer then the computer has a malware or configuration problem. Maybe temp files are set to go to path that the usb stick gets when it's inserted. Identify the source of the issue then solve. stick vs machine
Nov 08, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Info on memory stick wont come up on another computer
If you have Nero software on your pc, that can cause a conflict and your Sandisk may stop working correctly. What i did was to send back my pen drive because Sandisk admitted they have issues with Nero. I hope they are as accommodating with you also
Jul 24, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Sandisk cruzer 2gb flash drive
Reset the whole memory stick via the PC should jog the memory and make it work.
Jul 07, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Problem with launchpad sandisk cruzer micro 16Gb mem stick (u3)
Start at the beginning. Look at how you entered your password and retrace your steps.
Jul 05, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Memory card is not working
>You need to have a card reader.
insert your card in the appropriate slot and wait for the detection by your computer.
>Then open your my computer in which you can see your card, right-click it and select FORMAT.
This should solve your problem.
May 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer 2.0
Hey,
you can copy files into the memory stick by first finding the files you want to back up, right click on them and copy, then open the memory card from my computer and right click and paste, the file will be copied and its now 'backed up' on the memory stick.
Let me know if you need anything else.
Thanks,
Ekse
Feb 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Toshiba DPF7XSE Logo
70 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
