Question about Electrolux Washing Machines
Zanussi/Electrolux Aquacycle 1500 FS1555W beeps but doesn't work
Zanussi/Electrolux Aquacycle 1500 FS1555W Washing Machine - beeps but doesn't work
My toddling son was playing with the buttons and dials when there was a small pop and the fuse in the plug blew. Since replacing the fuse the machine still won't work.
when I select any programme it gives a short beep once, then five beeps with the end light flashing simultaneously then pauses and then repeatedly beeps four times with the end light flashing simultaneously again.
Any ideas on whether this is a home fix job or engineer call out job?
thanks Ade
  • 1462 Answers
SOURCE: zanussi electrolux aquacycle 1400 xc 6 fx1465 w
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Posted on Mar 21, 2007
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Posted on May 31, 2007
  • 1294 Answers
SOURCE: Zanussi manuals
Click on 'washing machines' (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Posted on Apr 04, 2008
  • 106 Answers
SOURCE: zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Posted on Feb 28, 2009
  • 1294 Answers
SOURCE: fitting of door seal on zanussi electrolux washing
Remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery.
To fit new seal
Lubricate the slot which fits over the tub with washing-up fluid - essential
Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange.When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands.
Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using in earnest. Use rinse to test as the water level is higher
Posted on Mar 12, 2009
Why will my zanussi FS1555 not start it only beeps at me???
Might be a problem with the door latch which is either not shutting properly or the door switch which could be open.
Look at item 7 in this diagram.
Zanussi FS1555W 91479119100 Washing Machine Spare Parts Diagram
Sep 02, 2014 | Washing Machines
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
Zanussi washing machine is making five beeps and not workign - what does this mean? It is not in the manual
My Zanussi Fs1555w is not finishing it's cycle and beeping 7 times. If I put on spin the cycle lasts less than a minute before the end button beeps, then it will beep repetitively 7 times until turned off. Please help
Feb 05, 2010 | Zanussi FS1455W Front Load Washer
Zanussi electolux aquacycle 1200 w/mc wont spin
Try new bushes and make sure where bushes run is clean and free from carbon H
Jan 09, 2010 | Electrolux Washing Machines
Zanussi aquacycle 1500 only beeps on the end function when i switch it?
does the machine spin properly i know on most zanussi's if the pump is blocked it will either beep or not do any thing there should be an out let at the bottom right of the machine.try that
Aug 02, 2008 | Washing Machines
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
Mar 20, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
211 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
