Question about KitchenAid Food Mixers
My kitchen aid mixer produced sparks inside the engine housing. There was a burning smell.
It wouldn't run at power levels below 4. I shut it off and turned it back on. This time it wouldn't run on anything but power level 5. The sparks got worse and the engine abruptly died.
  • Jessie Hutchison
    Jessie Hutchison Mar 18, 2014
    Oh also: it's a 325 watt heavy duty stand mixer. It is NOT a tilt head.
  • KitchenAid Master
  • 1,238 Answers
Check the carbon brushes under the black screw caps on the side of the motor, they may just be worn out. The brushes are keyed by way of a missing corner so only fit one way. You will need a torch.
Posted on Mar 18, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Burned motor, return to store if covered by warranty, or else have motor rewinded by expert motor technician
4 Suggested Answers
SOURCE: Kitchen Aid Classic Mixer
I have this problem too -it is rather common if you search the web. There was a suggestion posted on this site about what to do. See http://www.fixya.com/support/t125253-mixer_leaking_oil I have also read about other people taking it to a Kitchen Aid repair place where they repacked the grease for about $45. I took mine apart and there is gobs of grease around the gears. Right now I am still trying to figure out what to do. I am going to have my father look at it to see what he thinks since he is good with motors. The Kitchen Aid web site says that the grease is FDA approved, so at least it's not going to kill you if a little gets in your food. Their suggestion is to take it out and run it for about 5 minutes at least once a week. They say it leaks if it is not used often enough. That logic doesn't make much sense to me, but you could try it. Mine seems to leak more when I run it because the grease heats up and liquifies more. I hope that helps. I'll let you know what happens with mine, once it's fixed. Lisa
Posted on Jan 19, 2007
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Posted on Feb 21, 2009
hslincoln
  • 235 Answers
SOURCE: Kitchen aid mixer drops metal shavings in the
Hi REDLACQUER. Sorry to hear about the metal shavings. This is probably not to best way to take iron in your diet... My first thought would be to ask if your mixer is still under warranty. If you’ve had the machine less than one year, then I’d let KA replace your mixer with a new one. However, I suspect like many who seek assistance from FIXYA.com, your mixer is out of warranty, so what can you do?
Have you been able to find exactly where the metal shavings are originating? From the symptoms you describe, it appears that the planetary/agitator shaft assembly may be rubbing against its housing and generating the metal shavings at higher speeds. Have you noticed any increased noise levels/squeaking/screeching when the planetary rotates? It’s also possible that the planetary is out of alignment and not rotating true. Could the agitator shaft been jarred or hit hard during set up or moving in or out of you storage cabinet? Or the shavings could be symptomatic of other internal gear problems, but that would be the least likely scenario as the mixers internal gears are pretty much self-contained.
The good news is that this can be troubleshot and fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, and feel adventurous. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the last file, KP2671XWH3.pdf (325.07 KB) listed under Parts List (24) (check to verify that it matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. I suspect your Planetary Assembly, Illus No. 15, is rubbing somewhere against its housing, Lower Gearcase, Illus. No. 24.
To gain access to these pieces you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. You need to remove the Transmission Housing (Illus No. 7) and remove all the lubricating grease from the transmission housing and gears (when removing the grease be on the lookout for shavings in the grease which would indicate excessive gear wear). This will allow you to remove Illus No. 25, 21, 18 & 19, Retaining Clip, Bevel Gear, Retaining Pin and Worm Gear Follower, respectively.
Once you remove the Retaining Pin (Illus. No. 18) the Planetary Assembly can be tapped down through the Lower Gearcase Assembly (Illus. No 24). With the Planetary removed, you can inspect it and the inside of the Lower Gearcase to determine where the shavings originated. Be sure to look closely at the Planetary Gear in the lower gearcase as well as the Agitator Shaft Pinion Gear (Illus. No. 12). That will also identify what parts need to be replaced, which you can order online.
You’ll need to replace the grease you removed with new grease. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as it may have ‘debris’ in it.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jan 12, 2010
Kitchen Aid HDPro 5 quart bowl lift mixer is making clunking, rattle type noise when mixing anything heavier than egg whites.
You are probably going to have to remove the top housing and look and listen while it is running. Does it lose drive when it is being noisy? You need to remove the back cover, the silver band with Kitchen Aid on it and that will expose the 4 screws holding the housing on. Remember fingers and tools OUT while it is plugged in or running. I can't be a lot more help to you, we don't have that model in NZ.
Mar 07, 2014 | KitchenAid Professional Heavy Duty Series...
Mixer won't start after mixing dough.
There is a good chance you burned up the electrical Connectors to the motor or you have have blown the FUSE that is located inside the housing. The Motor has a Self Shut Off when it overheats but if you have over taxed the motor more than once, then there is a good change you need to repair/replace it with something that can handle harder work. My sister got a Mix Master the same time I got my Kitchen Aid, My Kitchen Aid is running strong since 2003 and her Mix Master died in 2005 and I bought her a Kitchen Aid. Sorry but I am not fond of the Sunbeam Mixer's.... Quality has gone down hill over the years to keep their prices low.
Mar 01, 2014 | Sunbeam 2386 MixMaster Series Stand Mixer
Sparks flying out of the back and smells like fire:-(
by replacing it with a new one. Not trying to be sarcastic. Your machine is done.
Jun 24, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Jun 21, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer revs, then shuts off, will not reset
your kitchen aid has a little device inside called the hall effect sensor. These often come dislodged or just stop functioning. If you are mechanically inclined you can replace this yourself.
Oct 01, 2009 | KitchenAid KV25G0X Stand Mixer
Mechanical burning smell on kitchen aid stand mixer
i think its time to retire it its has had a good run time to put it to rest and buy a new on it don't sound safe to use anymore
Sep 21, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen Aid 10 speed 325watts
Some of the gears may have broken or slipped off. You'll need t open it up to see why the shaft from the motor will not spin or you will burn out the motor with the power on trying to make it go. It might be a DIY job if you can see an obvious problem like a slipped gear, otherwise take it to a repair specialist.
Apr 30, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Food made with KitchenAid Stand mixer tastes like grease
The likelyhood of grease coming from the mixer is extremely small. As long as the beater & bowl were washed first and the shortening you used was fresh, there shouldn't be a grease taste.
Feb 17, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Food Mixers Logo
316 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
