Question about Radio Communications
Fan noise ts-2000 - Radio Communications
Kenwood ts-2000 internal antenna tuner fail to tune
it's not failing to tune, it shutting off as tuned. 1.25:1 is below it's threshold to tune
Feb 05, 2014 | Kenwood TS-2000
Ts-2000 doesn't TX
Driver & or Final transistores?
Jan 28, 2014 | Kenwood TS-2000
The fan motor makes a noise when it's running. I'ts 7 yrs old.
The noise could be the blade is coming loose on the shaft. It would need to be tightened. Or it could be it is striking the frame.
Feb 21, 2013 | Maytag Freezers
Vibrating noise when turn on heater/ac fan on 2000 pontiac bonneville
either fan motor is going out ar broken fan wheel, or possibly loose fan motor.
Sep 27, 2012 | 2000 Pontiac Bonneville
Intercooler TS makes Loud Noise when i start up my xbox 360.
clean the intercooler of any dust and the noise will disappear
Dec 18, 2010 | Nyko Xbox 360 Intercooler Ts
TForhe thermostat only works on the highest setting
Thermostats don't make noise. Do you mean the fan? First replace the fan switch, next replace the fan.
Oct 15, 2009 | 2000 Ford Focus
TS-450S Noise Blanker, No 1 & No 2 neither has any effect on noise
The noise blanker settings on the TS-450S (and S/AT) are true noise blankers and should not be thought of as a DSP device or something that they are not, like a notch filter or IF shift and etc. They will do a fine job of eliminating ignition noise as well as eliminating the electric mixer or blender noise from the kitchen...... however they will not remove static crashes or quieten those atmospheric noises on 75 meters during summer time thunderstorm season activity.
Hope this helps!
Apr 15, 2009 | Radio Communications
Cannot find License Server
1. TS and TS licensing server are installed in the same 2003 server. The lsview doesn’t list any TS licensing server.
2. If you open the Terminal Server Licensing, it shows “Finding servers… Connecting to \\apps\chicagotech.net. It never finds the apps server. There is not apps server in the network (They might remove this server from the network). After finishing the finding, there are two activated licensing servers listed, one is Windows 2000 server as 2000 TS licensing server and another one is Windows 2003 (also TS) as 2003 TS Licensing server.
3. The 2003 TS Licensing shows they are using Temporary License.
4. We modified the 2003 TS registry to point Licenseserver to itself (TS and TS license are the same server). That fixes the logon screen slow showing issue but not TS licensing issue.
for further querry
post comment
Oct 16, 2008 | Sibelius Computers & Internet
Radio Communications Logo
76 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
