Question about Acer Aspire 5100 Notebook
Failed to initialize common updater subsystem
The messege asks to make sure the McAfee framework service is running , common framework returned error 80080005@2
  • 334 Answers
Easiest thing to do is reinstall, saving a backup of you security settings would be helpful too. reinstall over top what you have so that you do no not need to worry about key numbers again
Posted on Jun 14, 2009
Updates fail
Microsoft have a .net removal tool which is sometimes helpful to do before reinstalling framework.if this does not work you need a full uninstaller like revo run it and remove scan registry markers.make sure firewall is off and mse is off before reinstalling fresh framework.
last resort is to reinstall over existing Os ...not fresh install!,, then update framework.this is because Microsoft employ too many cooks and the broth is inedible!
Feb 09, 2014 | Microsoft Windows XP Professional
The application failed to initialize properly (0xc0000135).
When attempting to run Microsoft .Net based applications, you may get the following error on startup:
The cause of this error is that the Microsoft .Net framework is not installed or is damaged in some way. Therefore applications will fail to launch.
To fix this error you can run Windows Update and find the Microsoft .Net framework update to install. Alternatively, you can download the Microsoft .Net Framework directly from Microsoft.
Aug 18, 2010 | Computers & Internet
Error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
May 28, 2010 | Microsoft Windows Vista Ultimate Edition
Mcafee scan not working
you will have to reinstall - you won't lose your subscription
Dec 04, 2009 | Mcafee Total Protection: Windows
Windows up date will not install error code 663
This is an error having to do with the .NET framework. You probably have version 2.0.
2. Now see Resolution Method 2 in...
When you try to install an update for the .NET Framework 1.0, 1.1, 2.0, 3.0,
or 3.5, you may receive Windows Update error code "0x643" or Windows
Installer error code "1603" (ignore the title, if need be)
After running the appropriate/needed tool, (re)install all .NET Framework
versions manually using the download links on the page then run Windows
Update manually to install security updates for same.
NB: KB923100 references this page:
http://blogs.msdn.com/astebner/archive/2006/05/30/611355.aspx. Please read
ALL of it as well as the related page
http://blogs.msdn.com/astebner/pages/8904493.aspx before using the .NET
Framework Cleanup Tool.
Or see the "How to obtain help" section of
http://support.microsoft.com/kb/953297
Nov 04, 2009 | Office Equipment & Supplies
My Fixya expert utility doesn't work. Error
Download and install the .NET Framework from this link : http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en
A quick Google search tells me this error means you are running .NET programs without having it installed. Surf to Windows update and patch .NET layer to your system. Horizons requires at least version 1.1 I think.
Jun 19, 2009 | FixYa Service
Error 1920 installing Mcafee 8.5
Good morning! If you receive a "1920" error regarding failure to start a McAfee Service when trying to update or install Mcafee VirusScan, follow the instructions below.
WARNING: This procedure involves editing the Windows Registry. Using Registry Editor incorrectly can cause serious, system-wide problems that may require you to re-install Windows to correct them. Use this tool at your own risk.
Solution
  1. Uninstall McAfee VirusScan Enterprise using the "Add/Remove Programs" option in the Control Panel.
  2. If present, delete c:\Program Files\Network Associates and c:\Program Files\Common Files\Network Associates
  3. Go to the Start menu, select Run, and type regedit .
  4. Find and delete the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Network Associates.
  5. Restart the computer.
  6. Install McAfee VirusScan Enterprise and update the software.
Best regards
May 07, 2009 | Computers & Internet
.Net Framework 1.1 sp1 Install Fails
You need to uninstall and install the latest version of .net frame work
You can download it from www.microsoft.com/downloads
Apr 15, 2009 | Microsoft Windows Vista Home Premium with...
When i try to use hallmark studio, i get the phrase application failed to initialize properly (0x0000135)
Please run windows update. It's important that you install Microsoft .Net framework & other security fixes.
When updating .Net framework there are many, please stay in order (smallest to largest). .Net framework 1.0.
.Net framework 1.1 & so on. When your PC has completed all updates try your program; hallmark studio again. If it still fails, reinstall the program & do not run other programs during install.
If you have more questions feel free to ask.
Good Luck & Kind Regards.
Mar 21, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
607 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
