Question about Garden
Blue max chainsaw manual
My chainsaw could not star. Help
Replace chain cover
Make sure the chain brake is OFF, line the side casing studs up with the holes and replace the nuts
Mar 27, 2016 | BLUE MAX 2-in-1 - 14"/20" Combination...
I HAVE A BLUE MAX CHAINSAW (BRAND NEW) AND i CANNOT GET THE EMERGENCY HANDEL TO GO BACK INTO THE RUN MODE. iT SEEMS STUCK AND WON'T MOVE. AM i MISSING SOMETHING?
if by emergency handle you mean chain brake ? are you pressing in on it (towards saw) as you pull back towards handle it's made to latch in chain stop mode on purpose
Apr 02, 2015 | BLUE MAX 2-in-1 - 14"/20" Combination...
How do i fix my pulley on my blue max chainsaw?
pulley . chainsaws do not use pulleys chain sprocket maybe have never had one go bad myself . I would take it to a repairman tho
Feb 11, 2015 | Garden
Why is my 14 &20 chainsaw Model 8901/8902 having difficulty pulling cord. It seems to lock. What could be the problem?
if it runs ok after you get it started it could be the starter pulley. the blue max saws have that problem
Feb 10, 2015 | BLUE MAX 2-in-1 - 14"/20" Combination...
I bought my husband a 2 pc. chainsaw set. Blue Max 14"-20" It will not stay powered up to make a cut, after it is started. We need to know where to take it for service, or what process is needed for a
A good idea to take it to home depot. Some of them have stations that work on fixing power tools and other things that break often. As for your problem it seems as if there is some sort of connection problem with the battery. Whenever you move it may jostle the connection enough to cut it off there for turning of the chainsaw. If you can check they battery and see if there are any loose cables that may help and if not take it to home depot.
Jan 29, 2015 | BLUE MAX 2-in-1 - 14"/20" Combination...
International 2010 pro star with the max force engine
You can order a manual from the dealer parts department or find one online through numerious forums
Nov 01, 2014 | Husqvarna Operator's Manual 365 372xp ...
What is the carb setting on a blue max 38cc chainsaw model 5466
Initial adjustment after rebuild is one full turn out on both low and high side.
Oct 14, 2014 | Garden
I changed the chainsaw chain on my Blue Max chainsaw. The kick-back seems to be locked
Bob take the chain off again and remember to tighten the tensioning bar so that the chain is slightly loose. Enough to pull a few cm of the bottom just to stop it being tight.
Aug 30, 2014 | BLUE MAX 14" Chainsaw replacement...
Brand new Blue Max 20" chain saw wont start, has fresh gas/oil mixed @ 25:1
I also have a BlueMax 45cc chainsaw that I could not start right out of the box. I got lucky a couple of times after many (20 or 30 pulls) but normally I just gave up. Many others online seem to be having this problem with this chainsaw.
It turns out the solution for me was that the starting instructions in the manual are not really complete, there is another step that aids in starting: it needs some throttle. The chainsaw does not like to start with power at idle. After setting the switch to on and setting the choke, as the manual says, before attempting to start, squeeze the throttle while pressing the side button to lock it. For me, this allowed it to FINALLY start with only a few pulls. I learned this when I ran across this video:
How to start BlueMax Chainsaw 45CC
Hope this helps anyone else who runs into this.
Nov 03, 2012 | BLUE MAX Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
