Question about Fellowes 3011001 Shredder
Fuse aurora paper shredder - Fellowes 3011001 Shredder
Aurora as1010cd paper shredder im having trouble removing the top
I would advise you to reconsider why you want to remove the top.
Oct 31, 2016 | Shredder Office Equipment & Supplies
I need new gears for my as501x-ms aurora paper shredder. Where can I purchase them?
Call Aurora customer service at 1-800-327-8508 USA
internationl only 1-310-793-5650
Jun 23, 2011 | Aurora Global AS501X-MS Shredder
Aurora AS1219 When a sheet of paper is fed the machine it runs but sounds like the motor is grinding. Remove the paper, it sounds the same. Is there a motor on the marked I can get?
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. Don't open your shredder to repair it yourself because it will void your warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Jan 27, 2011 | Aurora Electronics Aurora 10Sheet Crosscut...
My AS101bCD Aurora shredder will not shred paper, green light on paper in nothing, will happily go in reverse, what can i do
Sounds like a problem with the switch. Replacement is the most likely option, switches cannot normally be repaired.
Jan 26, 2011 | Aurora Electronics AS1018CD Shredder
I have an Aurura model A S 860 C paper shredder. It only runs in reverse.? Help
I unplugged it, took out some paper, wiped it down since there was alot of white dust and used my son's air spray can and sprayed both top and bottom of the teeth and away it went again with no more issues so far. If this doesn't work, then I will also do Bernard's fix.
Sep 07, 2010 | Aurora Electronics AURORA - Aurora paper...
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
Cannot get it shred forward or reverse. Is there a reset or fuse Paper shredder
probably has broken gears. Aurora does not produce replacement parts for any of their machines. Actually made by Royal and they don't make parts either so don't buy either brand.I guess Fellows is about the best brand or GBC.
Nov 13, 2009 | Memorex Paper Shredder
The shredder will not cut the paper. the motor
I just had this problem. I took the screws out from the bottom of the shredder and opened it up, take a look and see if there are any cracks around the frame that surrounds and holds the shredder in place, if so you have to glue the crack so the frame is stable again.(the crack/break in the frame prevents the paper from cutting because the teeth on the shredder are not fitted properly). hope this helps.
Aug 28, 2009 | Aurora Electronics AURORA - Aurora paper...
Aurora AS1010TX Will run forward for 1/3 of paper then into reverse.
I'm going to say it needs oiling. Try oiling the gears and cutting blades. You can buy paper shredder oil at Office Depot or Office Max.
Jul 10, 2007 | Aurora Electronics AS1010TX Cross-cut...
Fellowes 3011001 Shredder Logo
52 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
