Question about Sentry Safe s Fire-Safe Home Floor Safe SF123CS
Safe its locked don't know how to open - Sentry Safe s Fire-Safe Home Floor Safe SF123CS
Can not open with combation don,t have key for safe
You will have to bust it open
try dropping it ******* conor or hammer and chisel. you can not pick the lock
Sorry only way is to wreck safe.
I just opened a bunch at estate with no key or combo
Hope this helps Mike
Feb 07, 2016 | Sentry Fire-Safe Media File - SEN6720
I have cs-2 safe the key is inside and safe is locked now I don, t know how to open it I didn't set code still on company code plz help me
call the company tell them you have a problem they might help you or call some one who opens locks
Sep 28, 2014 | Locks & Locksmithing
How do I lock my safe?
If you have it open and you know the combination you should be able to close it and turn the opening handle and spin the dial to lock the door. But do not do this unless you for sure KNOW what the correct combination is because if you do not and you get it locked you will not get it unlocked. Run the combination while it is opne now to be sure it is fully opened etc. which it sill need to be to lock it.
Sep 19, 2014 | Home Security
Got old honeywell safe No:HWF19004340, no key and don't know combination. Can it be opened?
contact a locksmith for the answer to your problem All safes can be opened by professional trades people.
Apr 06, 2013 | Safe International Digital Electronic Safe...
SIM is lock
Using remote unlocking method you can solve this problem .........
Get the unlock process for your iphone here Mobile-unlocker.com , it gives easy instructions for getting the unlock for your mobile at a safe way........
Dec 11, 2011 | Apple iPhone Computers & Internet
Hi, I have a Brink's Safe model #5059. Actually it was my husbands and he just passed away. Unfortunately, I don't know where the key or the combination. I need to get a key to open this. Can you...
Brinks will not help you with this, but you should be able to get into the safe if you call a locksmith. Brinks use a really cheap lock tumbler on models similar to yours and it's easy to pick for a skilled locksmith. So easy, in fact, that you really won't want to use that safe again as it's really an unsafe...
You can watch an example of how easy it is by clicking here.
Jul 26, 2011 | Locks & Locksmithing
I forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Sep 14, 2009 | Locks & Locksmithing
Kingavon safe 28 door locked open, how do i reset code?
electronics not working can t find key need one but don t have any addresses or telephone numbers can anyone help
Jul 17, 2009 | Safe International Digital Electronic Safe...
Need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Apr 06, 2009 | Safe International Digital Electronic Safe...
Sentry Safe s Fire-Safe Home Floor Safe SF123CS Logo
37 people viewed this question
Top Sentry Safe Computers & Internet Experts
David Payne
David Payne
Are you a Sentry Safe Computer and Internet Expert? Answer questions, earn points and help others
