Question about Sony KDF-E55A20 55 in. LCD Television
WHAT DOES 3 FLASHES MEAN?
WHEN I TURN MY TV ON IT TURNS OFF AFTER 5 MINUTES BEING TURNED ON.WHAT COULD THAT BE DUE TOO?
    Top Expert:
  • Sony Master
  • 74,377 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Posted on Mar 18, 2014
Sharp Aquos LCD TV Error Codes power flashes twice and opc flashes 5 times - What does this mean?
Sure - but you need to find out what the new error codes stand for and be guided accordingly. You might want to check on the Sharp web site.
Your t con board might also have gone south.
Jun 10, 2016 | Sharp LC-52D62U 52 in. LCD HDTV
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Sharp lc-46le830u LCD tv does not turn on white arrow flashes 2 times slow than a pause and than flashes 5 times quick .it flashes this pattern over and over.what does this code mean?
It doesn't correlate to tthe trouble code in the users manual which are written. It sounds like a motherboard error. Try a cold reboot. Unplug the TV for 2 minutes then restart the TV and anything it is attached to. Unplug all first.
Feb 17, 2013 | Sharp Aquos Televison & Video
Sony KP-53HS10 AND "5" FLASHES at Timer/Stand by Indicator
i had the same problem someone told me to take the front cover off were the speakers are there the middle were you change the channels take them screws out and becareful there is electric stored up in there dont touch anything there is a square box with3 screws on top and three screws on bottom
turn your tv to video 1 and the first screw on top closes to middle turn it to your right a little at a time you will see bright colored lines then turn it to the left until they go a way then do the same with the other 2 on the top then shut off tv for 5 mins turn back on ahit the focus button it workd for me but be careful
Mar 03, 2009 | Sony KP-53HS10 TV
TV turns on for about 5 minutes then shuts off.
The projection lamp is out and needs to be replaced.
Jan 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Green Flashes - Shuts off
Sounds like the green picture tube is defective. To confirm you can take the front grille and door off and tap the green tube lightly with something plastic, and not to touch any of the adjustment controls to confirm.
Apr 12, 2008 | Sony KP-57WS500 57" Rear Projection...
DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Sep 18, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Sony KDF-E55A20 55 in. LCD Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
