Question about Roku XD Streaming Player 1080P Wireless-N (2050X)
Synchronizing with account - Roku XD Streaming Player 1080P Wireless-N (2050X)
Tip
How do you Sync your Android SD Card with Google
<p>A phone with Android can synchronize accounts with Google Gmail, Google Calendar and Google Contacts. You can select what to sync Google Account if you do not want them all, all computers and sync Android phone. Manually synchronize your accounts when you make changes that are not reflected on your Android phone. <br /> <p><br /> <p>1. Tap the "Applications" below. <br /> <p><br /> <p>2. Scroll down until you app "My Account" and tap it. <br /> <p><br /> <p>3. Choose your Google Account and customize your synchronization options. Gmail, Calendar and Contacts synchronization are available and you can turn on and off at will. <br /> <p><br /> <p>4. Press the menu button Android. Tap the "Sync Now" synchronization between your phone and select the Google Account and power applications. <br />
on Aug 18, 2011 | Google Android
Tip
How to Synchronization contacts between Android and Nokia (Symbian and Android)
<p>You cannot directly transfer contacts between your Nokia phone and your phone Android, because operating systems are different. You can import your contacts from your phone using Google Android to Sync your contacts from Nokia to synchronize with their Google account. The Android phone has a feature that synchronizes with your Google account automatically, so you can use your contacts on your Nokia phone to get Android. <br /> <p><br /> <p>1. Go to your Nokia phone. Load your "MFE" folder. Start the Mail for Exchange application on your phone. <br /> <p><br /> <p>2. Select "Yes" if the Nokia will prompt you for a synchronization profile. Click "Connection". "M.google.com" field enter the Exchange server. Confirm that the secure section is set to "Yes", your access point is set to your data connection for your Nokia and the port is set to 'default'. <br /> <p><br /> <p>3. Click on "References". Enter your e-mail in full Google Account username column. Enter the password for the account. Click on "Always On" so that your data is always synchronized. Go to the "Contacts" tab. Select "Enable". <br /> <p><br /> <p>4. Go to your Android phone. Tap your "All Programs" button and go to "my bills". Touch your Google account you just sync your contacts with Nokia. Tap the "Sync Contacts" if it is not synchronized. If your Nokia syncs your contacts with your Google Account pushed the contacts on your Android phone. <br />
Why am I getting no emails on my tablet
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
  1. From the Home screen, open the Settings menu.
  2. Under Personal, touch Accounts & sync or Accounts.
  3. To turn on or turn off Auto-sync
    • Touch the switch at the top of the screen.
      HTC Sense Samsung TouchWiz
      1. From the Home screen, tap the Menu key.
      2. Tap Settings.
      3. Tap the Connections tab.
      4. Tap Data Usage.
      5. Tap the Menu key.
      6. Check/uncheck Auto sync data.
  4. Touch an account to adjust settings, turn on, or turn off sync.
    • MobileLife Contacts
    • Google (appears if set up)
    • Microsoft Exchange ActiveSync (appears if set up)
    • Others, depending on apps installed
  5. To synchronize all accounts manually, touch Sync all.
  6. Press the Home key.
Android 2.1 / 2.2 / 2.3
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Accounts & sync.
  4. Under General sync settings, turn on or turn off:
    • Background data
    • Auto-sync
  5. Under Manage account, touch an account to adjust settings, turn on, or turn off sync.
    • Exchange ActiveSync (appears if set up)
    • MobileLife Contacts / T-Mobile / T-Mobile Contacts
  6. To synchronize all accounts manually, touch Sync all.
  7. Press the Home key.
Android 1.5 / 1.6
  2. Touch Settings.
  3. Touch Data synchronization.
  4. Turn on or turn off Auto-sync.
  5. Touch an account to turn on or turn off sync.
    • Gmail
    • Calendar
    • Contacts
  6. Touch Menu.
  7. To synchronize all accounts manually, touch Sync now.
  8. Press the Home key when sync completes.
Feb 19, 2015 | Samsung Galaxy Cell Phones
My android use my recharged airtime without using it
There are background processes that do this. I'd guess that it's primarily synchronization doing this.
for an unrooted phone (which yours probably is)
In ICS, JB and KK, go to settings / accounts /[probably google] and you will see the account(s) you used to setup your device.
Click your account and you will see a list of services, potentially with boxes ticked to the right. ticked (or checked) means "synchronize". Turn off the ones you don't want. If you want some things just synchronized when you're on wifi (so not using your $$$) check out AutoSync
https://play.google.com/store/apps/details?id=com.redwolf.autosync
Some of your data is also being used by advertisements. Yhe worst offenders are the "push" advertisers who put things on your screen whether the app is running or not. All you can really do us uninstall
for a rooted phone:
install afwall+.
https://play.google.com/store/apps/details?id=dev.ukanth.ufirewall
You can set per-application internet permissions (wifi, 3/4g, roaming). Not just synchronization - everything.
May 12, 2014 | Cell Phones
How to log out from gmail from xperia x8
it's not only to gmail.. x8 has application name "Google App" which includes gmail,gtalk etc.. with one account you are able to sign in all this.. so to logout or to be sign in with another account.. try this..
open Settings-->application-->manage application-->Google App-->Clear data
also clear data of gmail..
than open Setting-->Data synchronization
this will ask you quick setup for google account..sign in with it via any google id and you may able to use gmail and gtalk now..
if gmail doesn't saw mails and says wait for snyc for long time than do following
Settings-->Data Synchronization-->gmail(synchronize now)
wait for some time and gmail will be started..
thank you...
Nov 10, 2010 | Sony Ericsson Cell Phones
I can't send or get e-mail when trying to use outlook on my touchpro 2
Try again make this settings my friend
The Mail tab is where you send and receive e-mail messages. Including Outlook E-mail, you can add up to four POP3/IMAP4 and web-based e-mail accounts in this tab.
To add an e-mail account
1. On the Home screen, slide your finger to the Mail tab.
2. If this is your first time to add an e-mail account, touch New Account on the bottom-right side of the screen.
3. Set up your e-mail account using the E-mail Setup wizard.
4. To add another e-mail account, touch Menu > Accounts > New Account and use the E-mail Setup wizard to set up your account.
For detailed instructions on setting up e-mail accounts using the E-mail Setup wizard, see Chapter 6.
To check e-mail
When there are new e-mails, the icon on the Mail tab and the respective icons of the e-mail accounts will show the number of newly received messages.
If you have installed the synchronization software on your computer and created a partnership with your device, then your device is ready to send and receive Outlook e-mail.
If you have not yet installed the synchronization software nor created a partnership, do so by following the procedures in Chapter 5.
Tip To set up your company e-mail account so that you can access Outlook e-mail messages wirelessly, you must set up your device to synchronize via an over-the-air connection with your company’s Exchange Server. For more information about synchronizing with your company e-mail server, see Chapter 7.
Add an e-mail account
To add a new e-mail account, you can do one of the following:
On the TouchFLO 3D Home screen, slide to the Mail tab and then touch Menu > Accounts > New Account; or
Tap Start > Messaging > Setup E-mail.
The E-mail Setup wizard then opens and lets you enter your e-mail account settings. See “E-mail Setup Wizard” in this chapter for details.
Jan 11, 2010 | HTC Touch Pro Smartphone
Why do I have to keep synchronizing?
The message refers to your account with Rhapsody. You need to "Synchronize" with Rhapsody to validate your licenses in which they verify that your account is valid. You should generally receive this message every 15 to 30 days. Best of Luck.
Oct 01, 2007 | SanDisk Sansa m240 MP3 Player
Treo 650 is not syncing with outlook calendar, but syncing with everything else.
You may have tried Exchange ActiveSync in VersaMail When you setup an Exchange ActiveSync account in VersaMail, you are asking your Treo to synchronize email and your calendar with an Exchance 2003 server. In order to prevent duplicates, VersaMail disables Calendar synchronization via HotSync while the account exists on your Treo. So if you are an Exchange ActiveSync (EAS) user, you have a choice; you either sync wirelessly or you can delete the EAS account in VersaMail and can then sync your Calendar via HotSync. You cannot do both unfortunately.
Sep 12, 2005 | Palm Treo 650 Handheld
'Reset' each time after hotsynching
Do you still have administrative access to your laptop? IIRC there are some problems with using PD with a non-admin account.
I would recommend that you back up the "good" backup data on the Laptop. In PD, Choose Tools/Options, the "Data Directory" entry shows where the data is stored (in a subdirectory that looks like the first six characters of the Palm's User ID)
Sep 11, 2005 | Palm Tungsten T3 Handheld
Roku XD Streaming Player 1080P Wireless-N (2050X) Logo
37 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
