Question about Euro-Pro Crock Pots & Slow Cookers
Won't heat to high heat - Euro-Pro Crock Pots & Slow Cookers
What settings are on the toggle switch?
Probably bottom = low heat; middle = medium heat; top = high heat
Nov 01, 2015 | Crock Pots & Slow Cookers
My rival crock pot model 5865 sticker on the heating unit that tells you high/low etc. fell off and now I don't know which position is high or low? Can you help? Can I buy a replacement sticker? H
L to R Round Left Button- Low-High - Warm Two buttons over each other Top - time up, Bottom, Time down Most Right Button - OFF Lights Left - HIGH Center - KEEP WARM Right - LOW
Nov 09, 2012 | Rival 5865-W 6.5-Quart Slow Cooker
All clad slow cooker won't heat up.
I tried to locate the manual with google, and had luck to find this page, they have the manual!
Enjoy my help.
Sep 20, 2012 | All-Clad (HCOF8H2MZQ) 65Quart Slow Cooker
Won't heat properly
check for connections to terminals at source and feed points and make sure the are rightly fitted tightly or it could be low voltage.
Jul 03, 2011 | Crock Pots & Slow Cookers
Hi the crockpot controls have erased the settings could you tell me what is hi...low or heat
Most crockpots have only two settings: low and high/heat. Use the high/heat setting for dishes that will cook in 2-4 hours. The low setting is for your "all day" cooking, typically 6-8 hours.
Hope this helps.
Mar 03, 2011 | Hamilton Beach 33141
My crockpot's cable was damaged from heat.
amy i would try to tell you how to fix this but i would cost you some money to buy all the things to fix it you might try to go to a tv repair shop and see if they could put another cord on it for you they might charge you 5-10 dollars for this k
Nov 03, 2007 | Rival 37601 6-Quart
Crock Pots & Slow Cookers Logo
Top Euro-Pro Crock Pots & Slow Cookers Experts
Tom Chichester
Vernon Taylor
Are you an Euro-Pro Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
