Question about Yamaha DTXplorer 5 Electronic Drum Set
Low battery drums don't sound right - Yamaha DTXplorer 5 Electronic Drum Set
Alesis DM6 kick/bass has a really low volume-any way to make it louder?
MAKE SURE WHEN YOU ADJUST THE VOLUME YOU PRESS
SAVE , GO BACK IN A CHECK VOLUME LEVEL TO A MAX OF 16
Jan 09, 2013 | Alesis DM6 Electronic Drum Set
The bass (kick) drum pad is not working. When i plug the kick cable into the kick pad, it does not project a sound when I strike it. I know the cable works because i tested it in the other drum pads, and...
If youve already tested the signal path and it works then your likely just dealing with a bad piezo inside the kick drum. The piezo is actually what detects the trigger. You could probolly replace it yourself it not hard typically just 2 solder joints but you'd have to buy the piezo. Call the manufacturer they should provide you with whomever distributs their parts locally to you.
Sep 08, 2011 | Simmons SD7PK Electronic Drum Set
I have the yamaha dd65 digital drum machine , they don't work at all , once I have turned the power on and I'm ready to play when I hit the pads it cycles through the voices then it stops the...
Make sure you have the ORIGINAL power adapter for this unit. It should say PA150 on it and provide 12 volts at 1.5 amps (1500ma). I am not sure of the polarity, but if the part number matches, you have the right one.
May 09, 2011 | Yamaha DD 65 Seven pad Digital Drum Module...
Hi, I have a Ludwig Classic Maple drum comprising: Bd 16x24, Sr 5x14 , Tt 7x10, Tt 8x12 , Ft 14x14 , Ft 16x16 . I am very happy with the sound of this drum, very powerful, resonant, and easy tuning, I have...
Here I've listed valuable reference information on bass drum tuning and achieving the lowest pitch possible. Some things are trial and error but once you fully familiarize yourself with drum tuning you should be able to achieve the sound you want. Hope this helps.
Kick Drum Tuninghttp://home.earthlink.net/~prof.sound/id6.html
Bass Drum Tuning Lesson http://www.drummerconnection.com/drumlessons/youtube/46667-bob-gatzen-bass-drum-tuning-lesson
Apr 05, 2011 | Ludwig Classic Maple Power Drum Set Shell...
A new DM7 drum set line out has very low output. It is connected with drum combo Stagg EDA40 and if combo drum inputs are used there is practically nothing to hear . With combo maximum volume there is...
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Dec 29, 2010 | Alesis DM7 USB Electronic Drum Kit
Very littel sound in white and black keys. normal
We can only guess at what model/brand you have.
OFTEN such low volume things can be traced to a burned out light used in some expression pedals that use light dependent resistors to vary the volume.
Be aware that on some organs things like rhythm drums MAY go through a different set of speakers and amps than the other voices.
Apr 30, 2010 | Music
Yamaha DTXtreme IIS Drum Moduel repair
Listen to the output with headphones to check for noise.
OFTEN the output of a drum machine is CORRUPTED by an inadequate sound system. The waveforms generated by a drum machine tax the sound systems. A bass drum output can drive the speaker cone such that it goes beyond the linear range that the speaker and amplifier can handle and this appears as "noise". The noise may sound like a buzz or totally break up.
Turn the volume down and see if EXACTLY the same noise appears at low levels. If not, then saturation of the amp and speaker is likely. Continued use while it is doing that will often destroy the speaker.
Nov 28, 2009 | Yamaha Music
Alesis-sr 16 sound low
Buy the correct adapter that matches the voltage AND current requirements of the unit. MANY universal ones do not and the original MAY have built in filter that universal does not.
You MAY also need to do a factory reset on the unit.
Oct 18, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesissr 18 drum machine lcd does not display
Check if there is a contrast setting... Unfortunately, sometimes the setting can;t be viewed when contrast is too low. Read your manual and find how to get into that mode if it exists and turn it up.
Jul 16, 2009 | Alesis Sr 16 Stereo Drum Machine
Yamaha DTXplorer 5 Electronic Drum Set Logo
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
