Question about Swintec Refurbished 8014-s Typewriter W/90 Days Warrant
The Return key does not work
All keys work except the Return key. I removed the cap to clean debris. It still didn't work.
  • Swintec Master
  • 3,594 Answers
Take the cap off, make a small spitball, push it down the hole that the cap goes into, if one doesn't do it try two this only a temp. repair it needs a new contact sheet.
DickyO
Posted on Mar 26, 2015
The return button doesn't work
Gently pry off the return key, make a small spitball 1/8" or so, push into the small square hole where the ret.key goes. If this doesn't work you will have to remove the key board and clean the key contacts.
DickyO
Feb 28, 2014 | Olympia Mastertype 3 Typewriter
3 keys on my Optima lagtop suddenly stopped working
There is an electronic contact just under where you cleaned with damp qtip, so that may not have been very wise! There are screws on the back side of your laptop that do not remove but do loosen and release the keyboard. release the keyboard and gentely get keyboard to pop up and reseat connection. normally on laptops, keyboardsare able to lift where the f keys are and then slide in the direction of space bar to f keys
Jan 30, 2013 | Optima Centrino Traveler 680009100095...
Keyboard on Inspiron Mini 10 is not working right. Had chocolate spilled on it. How do I clean it.
Because laptops are portable, people tend to eat and drink over them. They lay the laptops on soiled surfaces and stuff them in dirty book bags. With all of the wear, tear and abuse that a laptop sustains, it's no wonder that the keyboard can become quite dirty. When a keyboard becomes dirty, often times the actual keys won't work. It is commonplace to find dirt, debris and food under the keys of a laptop computer. This causes the keys to not engage properly, rendering them useless.
1.Run a duster over the keys of your Dell laptop. This will remove any dust or small bits of debris that are causing your laptop keys to get stuck and not work. Test your keys once you have dusted them.
2.Spray the laptop keyboard with condensed air. Hold the air nozzle (you will often insert a small plastic tube into the nozzle) about 4 inches from the keyboard. Spray liberally, and use a back-and-forth motion while you work. This will remove most pieces of debris that may be stuck under the keys. Test the keys to see if they now work.
3.Place the tip of your flat-head screwdriver underneath the right-hand side of the key that is not working. Lift up gently and the key will pop off.
4.Dip the tip of your Q-tip into the rubbing alcohol and rub around the area where the key meets the keyboard. This will remove any final bits of dirt and debris. Allow the area to air dry. Repeat on as many keys as needed.
5.Place the loose key directly over the space where it belongs. Note the small piece of rubber. Hold the center of the key directly above the rubber piece and press down. When you hear a small clicking sound, the key is secure.
Sep 09, 2011 | Dell Inspiron Mini 10 Notebook
Some key is not working
just remove cap of keys and clean the surface from any dust or any stuff like carbon once it will proper clean put all key caps again it will help
good luck
Aug 20, 2011 | Computers & Internet
My keyboard automatically typing letter z and /////////... continuously even without pressing my keyboard. how can i solve this problem? thanks..
One of two things are happening. Either your keys are stuck due to debris and/or dust on your keyboard or someone has created "hot keys" possibly as a joke and they are typing it. Get a coin and insert it under the key and pull upwards. Keys pop on and off the keyboard. It will not hurt it. Remove both keys and check for dirt and dust under them. If this is not the problem then you have hot keys set. In order to walk you through disengaging them I would need to know your operating system and if removing and cleaning the keys worked first. Please let me know this by going back to your original question posted on fixya and using the comment or reply button.
Nov 28, 2010 | ASUS 90-A4C1K1000 Keyboard
I need a new 1990 Beretta gas tank key
Hi!!
If the cap is OFF the tank or if is ON the tank and have enough gas, you can have the key made at any key shop for about $5 if it's OFF or about $25 if it's ON. which is more than what the cap is worth.
If the cap is ON the tank, you better ff removing the little circle where the key hole is and pull out the key tumbler, if you can't do it, insert a medium to large size flat head screwdriver into the keyhole and turn hard counterclockwise until the tumbler gives up and cap can be removed. be careful not to let any debris get into the gas tank. REPLACE WITH NEW CAP.
Good Luck!! Don't forget to rate this post!!!
Aug 23, 2010 | 1990 Chevrolet Beretta
Certain keys are creating double letter combinations e.g. typing "y" yields "hy", "i" creates "ki", "r" "fr", and "o" brings "o9". the shift key has stopped working. replaced batteries. took off key caps...
i think maybe some of your keys are stuck together. have you spilt something on it or is there a load of debris underneath keys if so just give it a wipe to clean it or blow on the keys to remove debris
Sep 26, 2009 | Dell 0Y3740 Keyboard
Kid spilled soda now keyboard will not type
Hi There !!
Thank you for choosing Fixya. The chances are rare that it would work, because liquid may have done damage to the integrated circuit.
But we can give it a try:
What you will need:
  • lint free cloth.
  • dry cloth or duster.
  • suitable cleaning fluid (isopropyl alcohol).
  • cotton buds.
  • Can of compressed air or vacuum cleaner.
  • Flat tip screwdriver (optional for thorough clean).
Shutdown your PC and remove the mains plug, unplug the keyboard(remember where it was plugged in) and hold it upside down to releaseany debris from inbetween the keys.
This is where the patience comes in, make a note ofthe position of all the keys or you will have trouble putting them backcorrectly, alternatively just remove the letter keys A - Z from the keyboard (which is where the most of the dust/debris will be) and refer to fig 1.4 as a reference to put them back.
All the keys can be removed although the larger keys (space bar, enterkey, shift keys, backspace, caps lock, etc) can be difficult to putback so you might avoid removing them.
Remove the keys using the screwdriver, ease the screwdriver under the key and gently lift the key top off (see fig 1.3).
note: don't forget to make a note of their position !! remove-key-cap.jpg keyboard-layout.gifWhen you have removed all the keys (except any keys youwish to avoid) use the compressed air (or vacuum cleaner) to remove anydust and debris from inside the keyboard.
Now is a good time to give the keys a proper clean, for bestresults clean each one individually (the patience thing again) with thecloth and cleaning fluid, when clean, wipe them over with the drycloth.
Before replacing the keys, take your lint free cloth anddampen it with your cleaning fluid (don't put the liquid directly onthe keyboard), give the surface of the keyboard a good wipe overensuring to clean as much as possible any keys that you haven'tremoved.
When the keyboard is nice and clean replace the keys according to your notes or if you have just removed the letter keys use fig 1.4 as a guide, to put the keys back on position the key in place and press gently but firmly until it clicks home.
After replacing all the keys give the keyboard a quick wipe over with your dry cloth and you have a nice clean keyboard.
Hope this will help !
Regard's
Sep 03, 2009 | Computers & Internet
Function Keys
hi there
you have lock the the number on the keypad to remove this function as caps on caps off simply press fn and key F11/numLK same time and it will return to normal letter function on your keypad
May 19, 2008 | Acer NSK8458AN Keyboard
Toshiba tecra s2 keyboard starts skipping typed characters and stalling
there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
pls remove the key board cap carefully and clean
Apr 29, 2017 | Toshiba Tecra S2 Notebook
Swintec Refurbished 8014-s Typewriter W/90 Days Warrant Logo
123 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
