Question about Kawai MP6 Digital Piano Keyboard COMPLETE STAGE BUNDLE
Kawai mp6, sticking key - Kawai MP6 Digital Piano Keyboard COMPLETE STAGE BUNDLE
How to reset kawai z 1000 piano
RESET / Hold these buttons or keys and power on Insert System disk. Hold POPS and power on. Display shows FIND SYSTEM and starts the loading process. Which version do I have? / Hold these buttons or keys and power on Input the following number code: 00009584 or look at Start Screen Which version is the latest? 2.46 How can I get the factory sounds back? RESET
Mar 24, 2016 | Kawai Music
Kawai mr-370 digital piano. Why is it stuck on the loudest volume and does not respond to the volume control slide?
The solder contacts on the fader may not be connected to the board. It may also be a software glitch. If you reboot / initalize the instrument it may fix it.
Dec 28, 2015 | Music
What is the piano age by serial number 1872
Hello, you will need to look inside the Factory's site. Generally, they put a link to this purpose. If not possible, try a search section in Google, using words like: "serial number" age piano Kawai, changing the Kawai word for the name of the maker of your instrument.
Aug 24, 2014 | Music
I would like to know the age of a Kawai KG-1 serial #470837
I know they were made in 1975 and also 1985. Don't know how many years outside of there.
Feb 27, 2013 | Music
Two of my keboard keys got hit by a child. They won't return to playing position. CLP-370
you'll need to open the keboard and check for the keys that has a missing mechanism on it. It usually is a stopper to prevent the keys from "sticking". You can use crazy glue or mighty bond to stick the broken parts together.
Hope this helps
Dec 22, 2010 | Yamaha Full-Size Keyboard
Keys stick down after being played. I have cleaned, vacuumed, blown air throught he keys, etc. now change. I have taken the keyboard apart down as deep as possible and cleaned again, the keys still...
The key is to open the unit and find the exact point these are sticking. It is unlikely that vacuuming and blowing is going to improve the situation. Often the sticking is due to deformation of the case at the front draging the keys... This would be very obvious and I am sure you would have seen it and found this if it were the problem. It is not clear exactly which type of key mechanism is used here. I have several keyboard with various mechanisms. Some of the weighted ones are actually made by a single company and used by Yamaha, Korg, and several others. These are rather complex and probably not like yours. Others use a silicone rubber dome with conductive rubber contacts that press against circuit traces... for these, the restoring force is actually from the rubber dome. If the domes wear or deteriorate, then keys will not come back up. Yet another type uses a spring at the back end...M Audio uses this lightweight in some of their products.
In your case, I would look for a pivot point that might need lubricating. I was unable to find a service manual for the NP30 that would show the exact type key. I have several Yamaha keyboards that have several types of keys.
If the keys may be dragging on the side, clean with Q tips... and then you can wipe with a Q tip moistened with CRC226 available at Home Depot in the electrical dept. This is a safe lubricant for electrical uses.
Nov 20, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
Keys sticking on Yamaha p120 digital piano....how do I open it up
you may not need to open it up.
try using a wax based furniture polish on the keys, it will leave a layer to act as a lubricant between the keys.
Aug 24, 2009 | Yamaha Full-Size Keyboard
Key sticks.
take it to the shop for repairs
Jul 02, 2009 | Yamaha Full-Size Keyboard
Kawai MP6 Digital Piano Keyboard COMPLETE STAGE BUNDLE Logo
29 people viewed this question
Top Kawai Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Kawai Music Expert? Answer questions, earn points and help others
