Question about Dell Inspiron 560s Desktop Computer Intel Pentium dualcore E5800 (DDPHCT191
Hard drive error - Dell Inspiron 560s Desktop Computer Intel Pentium dualcore E5800 (DDPHCT191
    Top Expert:
  • Dell Master
  • 5,143 Answers
Have you tryed another harddrive to see if it picks that one up?
you may of lost the windows bootup.
Posted on Apr 05, 2015
I have a 1/4 red ring in the lower right how bad is this and what do i do
That denotes some sort of hardware error... there should also be an error o the screen when you boot up the Xbox...
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: (not yet known)
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Apr 19, 2011 | Microsoft Xbox 360 Console
Boot disk failure no hard disk found
The error means that your system is not able to detect the hard drive on the system, check if the hard drive wire connections are tight and not loose and then try rebooting the system.
Look for hard drive stats on POST whether it succeeds or fails. This is how you can do that.
When system boots up, press the PAUSE?BREAK on the black screen and see whats system comment for your hard drive power test. If it succeeds and your hard drive's connections are also tight then possibly your hard drive might have crashed ( which means there are bad sectors on the hard disk).
Try performing disk checking on the hard drive to see if there are any bad sectors on the hard disk, the disk check will automatically fix the soft errors but if the errors and hard errors in that case the disk checking utility will not automatically fix the errors and you will need to get a new hard drive.
Thanks !!!
Nov 22, 2010 | Computers & Internet
Wont let me play says send error report
Well most xbox units in the US will have a code with the xbox error report, you need that code when calling microsoft customer support at 18004myxbox. If it goes to a black screen and gives an error code here is a list of known codes.
If the xbox is telling you something is wrong via the rings of death just make note of what the colors were and where they were.
Sep 10, 2010 | Microsoft Xbox 360 Elite Console
E 73
moz-screenshot-3.pngmoz-screenshot-4.pngmoz-screenshot-5.pngmoz-screenshot-6.pngmoz-screenshot-7.pngThis problem is fixable, I had similiar problem with my clients XBOX360 console ( I run an electronic repair shop) and get customers frequently with this Error. I was able to fix couple of consoles with the help from this XBOX360 Repair Guide
You can download the repair guide and fix most common problems with your XBOX console. There are also other errors which are covered in the guide, so you can fix them as well!
Oct 05, 2009 | Microsoft Xbox 360 Console
Xbox is showing one red light in the lower right hand spot. How do I fix this
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E64: (not yet known)
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
Sep 24, 2009 | Microsoft Xbox 360 Console
"Error loading operating system" message
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 09, 2009 | Sony VAIO VGN-FE660G Notebook
Hard disk error
Unfortunately this error occurs with a fault hard drive. You will need to replace the hard drive and then reinstall the OS.
Mar 20, 2009 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
It has the bottom left ring
Hello my name is Tim Ehrhart and I hope this helps The Specific Type of hardware failure can be determined by the error code displayed on the screen.
Please leave feedback as I am new and wanne gain a good rep. Thnk You
Mar 12, 2009 | Microsoft Xbox 360 Console
500GB MY BOOK hard drive.how to clear "disk error" & use again?
when you reboot your computer, do not have the hard drive attached. As far as the error goes, im not to sure about that.
Jan 27, 2009 | Western Digital 500GB My Book World...
Dell Inspiron 560s Desktop Computer Intel Pentium dualcore E5800 (DDPHCT191 Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
