Question about AT&T GoPhone Z998 4G
On the z998 phone how do i remove the screen lock that is set on pattern lock
How to unlock or bypass screen lock pattern ?
How to Remove a Password on an LG Optimus by Ruri Ranbe, Demand Media
The LG Optimus M doesn't offer you many alternatives if you forget the pattern to unlock your smartphone. After all, if it were easy to bypass the lock, it wouldn't do much in the way of security. If you don't remember your pattern, or if someone created one without your permission, you have two choices: sign in to your Google account to remove the lock, or perform a factory reset of your device. If you don't have a Google account, the latter option is your only solution.
Sponsored Link Start Download Now Convert From Doc to PDF, PDF to Doc Simply With The Free On-line App! www.fromdoctopdf.com If You Have a Google Account Step 1 Press the "Forgot Pattern?" button, and then enter your email address and password into the appropriate fields.
Step 2 Tap "Sign In" to log in to your Gmail account and bypass the lock pattern.
Step 3 Go to the Home screen, press the "Menu" key and then tap "Settings."
Step 4 Tap "Location & Security" and then tap "Set Up Screen Lock." Follow the on-screen prompts to redraw your lock pattern.
If You Don't Have a Google Account Step 1 Press the "Power/Lock" button and then choose "Power Off" from the pop-up menu to turn off the LG Optimus.
Step 2 Press and hold simultaneously the "Volume Down," "Home" and "Power/Lock" buttons for at least five seconds to reset the device.
Step 3 Release the buttons when the phone turns on.
https://play.google.com/store/apps/details?id=net.thomascannon.screenlockbypass.pro
Sep 18, 2015 | Virgin Mobile - Lg Optimus Elite Mobile...
Remove Screen Lock pattern
Go to setting-> Security-> Lock options->change it
May 20, 2015 | Cell Phones
How to remove lock icon on boot screen on galaxy note 3
go to settings => lock screen => click on the 'shortcuts' or lock screen widget shortcut (forgot the name). There you can change or remove it
Jul 02, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Disable the screen lock I initiated
From the home screen, press the Menu button (1st one on the left with 3 bars) then tap settings, then location and security, then set up screen lock, pattern. There you should be able to turn it off/on
Jun 21, 2014 | Motorola Mobility Defy Mini XT320 Black...
When i am talking on the phone, it goes to airplane mode and i cannot use the phone...how do i fix or lock the screen or get the airplane mode off of the quick touches
This will help to reduce the frequency of this issue occurring. I have the same problem and have not yet found a way to remove the Airplane Mode option form the action bar pull-down for the Z998 phone. It is a ZTE firmware issue, not Android.
UNDERSTAND WHAT HAPPENS: when the phone moves slightly away from your ear while talking, the proximity sensor detects that it is not close to your face and it turns the display back on as it should. The screen often comes on with the action bar pulled down and thus all the controls exposed. A moment later your phone touches your ear before the proximity sensor had caused the screen to go blank again, so whatever your ear touches, can become an actual user command, even though unintentional. Unfortunately the Airplane Mode is one of the first selectable options on the Action Bar. You might sometimes notice that Bluetooth, Sound or Mobile Data gets toggle also; at least that does not cause you the dropped call. The problem gets worse when you walk or move around or fidget a lot while talking.
THIS HELPS: manually turn the screen off (press the power button) after you answer the call. Because you deliberately power off the screen, the proximity sensor is bypassed. The job of the proximity sensor is to turn on/off the screen to save battery (the reason of course that when the phone is against your ear, you cannot possibly also look at the screen, hence the proximity sensor turns it off for you). You will soon get in the habit.
Apr 01, 2014 | AT&T GoPhone Z998 4G
I want to set screen lock in mysamsung corby gt s3653
GO UNDER SETTINGS SECURITY ,PASSWORD PICK PASSWORD INSTED OF PATTERN
Sep 22, 2012 | Samsung S3650 Corby / S3650 Genio Touch...
I need to unlock samsung gt 15500 locked by too many patterns attempt
Forget that stupid 'sim unlock' instructions as that is clearly not your problem. Pattern lock has NOTHING to do with sim unlocking.
You can remove pattern lock for free here:
http://www.unlocksamsungonline.com/free-phone-lock-unlocking/
Instructions;
1. turn phone on, wait on screen asking for pattern lock
2. connect to computer (install drivers, this can be done while installing their software)
3. login with 'test' - 'srscom'
4. select your phone model and click rescan (or manually set port)
5. hit 'Reset user code' button
6. done
Best regards,
Jun 14, 2012 | Samsung Cell Phones
I had set up a pattern lock in samsung galaxy pop gt-s5570 and it shows too many pattern attempts to unlock, sign in to your google account, but it doent work
May 10, 2012 | Cell Phones
How do i lock the screen and unlock it
You can lock the screen of your HTC Hero screen with a draw pattern. Here's where to set the feature in the Android software.
1. From the Home screen, press Menu.
2. Tap Settings.
3. Tap Security.
4. Tap Set unlock pattern.
5. Read the info, then tap Next when ready.
6. See the pattern, then tap Next.
7. Draw the screen unlock pattern with your finger by connecting four or more dots in a row.
8. Tap Continue.
9. Draw the same pattern again.
10. Tap Confirm.
hope this helps
John
Sep 14, 2011 | HTC Hero Smartphone
AT&T GoPhone Z998 4G Logo
42 people viewed this question
Top AT&T GoPhone Cell Phones Experts
Dustin
Dustin
Lawrence Oravetz
Are you an AT&T GoPhone Cell Phone Expert? Answer questions, earn points and help others
