Question about Sanyo SR-3660S Compact Refrigerator
When i turn it on it harley makes any sound - Sanyo SR-3660S Compact Refrigerator
Wont turn over
When you say "makes the sound like it wants too", is that the starter motor making the sound, or just a click?
Your heading said "Won't turn over", which means the starter doesn't turn at all.
If it's makes just a single click each time the starter button is pushed, that usually is the starter relay, a $15-$20 part.
Mar 18, 2014 | Harley Davidson FXSTDI Softail Deuce...
Harley Davidson Dyna superglide sport 2000 won't start
Hi Dave, check to make sure your ignition switch has not melted at power post. for a free wiring diagram please to visit website below:
Harley Davidson Wiring Diagrams and Schematics
Good luck
Apr 15, 2012 | Harley Davidson FXDX Dyna Super Glide...
1988 sporter want start just make clicking sound my battery is charge the cables is tight all i get is a clicking sound
tap the starter,, you may show 12v as the charge on the battery , but it may not have the amps required to turn over the bike, Harleys are known for high amps needed to start , see if jumping starts it, if so,, replace the battery
May 17, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Horn does not work
This is common with Harley's horns. There is a screw on the backside of the horn. Turn this screw in very small increments until the horn starts sounding again. If it never does, you need a new one. Make sure you check the ground on the horn.
Jul 27, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
1995 Harley Sportster won't turn over.
sounds like the battery has dropped a cell,it will still have power but not enough to turn the bike over properly,harley atarters use a lot of current to turn over so a slightly weak battery will cause all sorts of grief,hope this helps...cheers
Jun 27, 2009 | 2007 Harley Davidson XL 883 Sportster
Standalone icemaker sounds like a Harley Davidson
check and make sure you don't have a piece of scale in the intake of the waterpump. the pump stops when the unit goes into defrost to dump the ice onto the cutter grid. also check the fan under the icemaker for lint buildup on the condensor
Dec 19, 2008 | U-Line Icemaker
Muffler
If you mess with those mufflers you are goin to loose back pressure and your bikes performance will suffer. Get some slip ons , Vance and Hines, or Rinehart or Sampson. You'll get the sound you want and your performance will be enhanced as well
Dec 03, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Sanyo SR-3660S Compact Refrigerator Logo
19 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
