Vacuuming debris from removal of carpet when cleaner hose became clogged. Cleared hose and replaced full bag. Cleaner does not have suction. Air coming out of vent in top of head.
Check the inlet down by the brush roll to see if it is clogged. Also check the belt to be sure it is ok. Is there suction at the hose? If not then it is still clogged.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 33721 Upright Vacuum
The brush wouldn't work when the selector switch was in carpet mode. Took the power head apart and...
(More)
The brush wouldn't work when the selector switch was in carpet mode. Took the power head apart and removed the motor. Everything o.k. in the power head. Checked and found that the neutural wire had pulled out of the connector, the connector was never crimped at the factory. What a day! Took 2 hours and a large pizza to get it done. Neutral wire was in the hose just below the handle. Reconnected the wire and crimped it, put everything back together. It works!!!!
I got the vacuum apart and put the new belt on the roller but don't see where else to put belt. Help...
(More)
I got the vacuum apart and put the new belt on the roller but don't see where else to put belt. Help please
My Kenmore upright bagless vacuum (Model# 116.36720600) just stopped working while cleaning. I've...
(More)
My Kenmore upright bagless vacuum (Model# 116.36720600) just stopped working while cleaning. I've changed outlets and still doesn't work. I think I might have killed the motor. Is there a reset switch or button for this vacuum or am I looking for a new vacuum?
