Question about Jeep Car Audio & Video
Jeep rear passenger door won't open - Jeep Car Audio & Video
SOURCE: rear passenger door will not open
I bought my Cherokee new and until 06 I never had a problem with the doors. When 1 latch went all the others went shortly thereafter. You WILL HAVE to replace the latches. I've done all 4 doors and the rear latch. You can do it relatively easy but the latch NEEDS to be replaced. You may get it to work every now and then, but it will FAIL again, just replace it and you'll be happy.
Posted on Apr 27, 2009
ZJLimited
  • 17970 Answers
SOURCE: rear door will not open
Review this reference documents: ZJ-Secc-8P-Power-Door-Locks (Page 4)
Good luck... and rated my help!!!
Posted on Aug 11, 2009
Kcameron001
SOURCE: rear passenger side door will not open
Remove the door card and connector block from the lock and feed a 12v supply to the lock connector. This should allow the solenoid to deactivate the lock.
Posted on Apr 26, 2011
  • 118 Answers
SOURCE: 2006 dodge caravan sxt passenger door sliding door won't unlock or open at all, manually or by remote
U will have to take the inside door cover off and manualy open it. And replace the electric door locking switch. Very common problem. Get the new lock and latch assembly from dealer,
Posted on Jun 13, 2012
SOURCE: rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Posted on Aug 12, 2012
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
2006 jeep liberty rear lift glass won;t close
Mine did this too....the latch kept getting stuck. If you put the key in the ignition and unlock the power doors, pull on the gate door (don't open it, just enough to release the latch), and it should come out so the hatch will latch.
Feb 18, 2013 | 2006 Jeep Liberty
Power windows and locks do not work
The power windows are protected by 50A fuse 12 in the power distribution center. The orange/white wires from the PDC go to the driver door module and the pasenger door module. The driver door module controls the front power window motor directly and applies power to the driver rear power window switch to allow passenger control of the rear power window. Similarly, The passenger door module controls the front power window motor directly and applies power to the passenger rear power window switch to allow passenger control of the rear power window. BUT, operations can be computer controlled as part of the access control/theft deterrent system.
The power door locks also are protected by 50A fuse 12 in the power distribution center. The orange/white wires from the PDC also go to the driver door module and the pasenger door module. The driver door module controls the driver door lock motor/ajar switch. The passenger door module controls the passenger front door lock motor/ajar switch and supplies power for rear seat passenger control of the left and right rear door lock motor/ajar switches.
In short, if power from the fuse is getting to the door modules all windows and doors should work. If not, there may be a defect in the modules, the separate control switches, or even in the motors.
Sep 09, 2012 | Jeep 2004 Grand Cherokee LAREDO 4WD
Rear passenger door won't stay closed
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
2001 Jeep Grand Cherokee - The rear passenger side door is locked and will not open. I cannot open from the inside - missing the manual.
sounds like the child lock is on and the outside mechanism is broke ,difficult job as you will have to open door by removing the door panel in situ
Dec 24, 2010 | 2001 Jeep Grand Cherokee
Passenger front /rear windows will not work 99 jeep gr cherokee
ill suggest theres a broken wire between the drivers door and the body in that accordian looking thing.
Sep 06, 2017 | 1999 Jeep Grand Cherokee
2004 GRAND CHEROKEE DOOR LOCKS
Ground wire (black) open between drivers door conector and door pillar due to flexing. Locate break and solder in some extra wire to relieve the stress when the door is used.
Sep 15, 2008 | 2004 Jeep Grand Cherokee
Car Audio & Video Logo
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
