Question about 831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS
, starts and stops my car 3 times in cold weather.
After its done the 3 times i hit the button again and it runs
    Problem Solver:
  • 14 Answers
Try increasing your crank time by the next increment
Posted on Mar 21, 2014
  • 508 Answers
Hate to this but take it in to a shop that can service this unit. The reason i say that is because these and most command starts have systems that tie into the main brain on the car. If the problem is not in the command start it is most likely going to be on the car, one of the sensors is not reading right in the cold weather and this sends a fault code to cars computer which is read by the command start and the system shuts down. After 3 times in the cold the sensor warms enough to NOT send a code to the cars cpu and no fault code is sent so the command start assumes everything is ok and keeps the car running. Will say that since i have never heard of this system i could be dead wrong all the way, but would suggest you start with that. Hope this helps
Posted on Mar 20, 2014
Honda prelude problems
run fault code and look at injector problems . have a fuel pressure test done to check pump--pressure regulator--filter
Jan 30, 2014 | Cars & Trucks
Van engine start but not run during cold weather
Check the fuel pressure, it could be a bad fuel pump
Mar 16, 2013 | 1993 Dodge Ram 250
94 caprice won't start after it rains have to crank over many times starts great during dry weather restarts in wet weather after initial hard start 4.3 V-8 I'm thinking distributor
94-95 B Bodies have a On Board Diagnostic Built in the AC System! Try holding the AC "OFF" and "TEMP^" buttons at the same time until the screen looks funny with all the lights on! the scroll with the temp up and down button till u see 00 and hit the button that says "MIDDLE" to enter! If done right, i will start displaying any stored dtc codes. tehn let me know what code it shows!
Dec 15, 2011 | 1994 Chevrolet Caprice Classic
Car overheats and AC stops blowing cold, then temp guage eventually goes back down and AC starts blowing cold, after a while overheats again and AC stops blowing cold again. problem just started after a...
Your AC system is supposed to shut down if the engine is hot, as a safety device-make sure when the ac is running , the radiator fan is blowing-it may not be, caused by either a bad relay, blown fuse or a bad fan motor. Make sure your antifreeze is fully up to level, and if you haven't done it in the past 2 or 3 years, get the cooling system serviced with a new thermostat-cheap insurance, you do NOT want to overheat that aluminum engine, because if you do, it will be toast.
Jun 23, 2011 | 1999 Honda Accord
My1999 f250 won't start in cold weather unless block heater is plugged in. Even after just sittting for a couple of hours in the cold it takes 9 to 16 rounds of glowplug warmings to start and usually dies...
3-4 years is a long time to run on glow plugs, reason why smokes so bad is you have all that raw fuel from trying to start. Glow plugs have failed, it only takes a few to screw up. but check power to plugs for proper ampherage
Feb 03, 2011 | 2006 Ford F-150
I have a UT20760 25cc Homelite Trimlite and I would like proper instruction on how to start the engine. Instruction on engine say to press fuel bulb 8 times, but I am not at all sure what position the...
Pull the cord with the lever in position 1, when it tries to run, put it in position2 and pull the cord again. Once it starts running, wait 30 seconds and put it in position 3. Operate in position 3 and hit the stop button when you are done.
Mar 25, 2010 | Homelite Garden
Fisher and paykel smart drive top loader , Wont fill properly .
Well where to start .....
This brand has a hell of a lot of quirks.
The first thing to try is this : With the power on at the wall and the machine off ,push and hold down the start button , then push and hold down the power button you may hear up to 3 beeps at this time (hold down the buttons for 5 seconds then release) turn machine off and turn it back on and just push start button.
What this does is re programes the computer ,then just leave machine to run cycle
Jun 12, 2009 | Fisher and Paykel Washing Machines
The doors lock when I start the car - I don't want that!
the unit can be programmed to lock the doors after starting, to make it leave it alone you have to enter the programming(ignition on, press the valet switch 5 times within 5 seconds, the lights will flash 3 times to signal you have entered programming, then press valet switch 10 times(lock after start setting) within 5 seconds hit the unlock button on the remote (button closest to the side with the other buttons)
then turn off the ignition to save the settings and it should be done
manual for the system is found at scytek.net under the download section
Apr 14, 2009 | Scytek 2000RS Remote Control
LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
May 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Mar 09, 2008 | Timex 1440 Nylon watch
831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS Logo
106 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
