Question about Drills
How to replace battery
Canadian tire
3 Suggested Answers
SOURCE: Can I buy replacement batteries for Shark Cordless Sweeper
I need a replacement battery for my Shark Stick sweeper model V1911 N. Can't find it on their web site. I guess it is old. Murnieruth
Posted on Dec 17, 2009
  • 31 Answers
SOURCE: canadian tire says tests fine. bought new battery,
open hood and check pcm wiring harness its located in the left back end of the engine compartment looking at it from the front of the vehicle. the wiring tends to become very loose
Posted on Feb 12, 2010
I'm looking for a 14.4 battery for a Mastercraft Circular Saw ...
Janet, you have a couple of choices. First, my guess is your saw is older and Canadian Tire does not make the battery pack any longer. There are several places you can send your battery pack to and they will replace the cells. There may be a local place. Your other choice is to replace the cells (individual batteries connected together to produce the 14.4v needed). The batteries/cells are available from BatteriesPlus and many other battery stores. However, if you do not have some basic knowledge of soldering, using a volt meter, etc. I would not recommend you change them. Some of these batteries when wired together pack a punch, some can actually weld. So, I would check to see if there is a local place to replace your cells or send it off would be the safest but not the cheapest choice.
Oct 23, 2014 | Saws
How to know if Canadian Tire Eliminator car battery is still good
Do you live in a cold climate ? Cold climates will reduce battery shelf life quite a bit and 2 years without use is deffently long enough for it to loose charge. I would try a recharge and see where it stands if charged use it see howlong it will last under load. if it dont work call canadian tire and see if you can get a battery inspection at there garage in know where i live they do them for free. Hope this helps sorry about spelling and good luck
Jan 16, 2012 | Cars & Trucks
Looking to talk to someone that makes eliminator batteries i bought one for my envoy not even twon years ago from canadian tire and now can't find the reciept and i really don't want to pay another...
YOUR ALTERNATOR NOT WORKING.HAVE BATTERY CHARGED UP.YOU SHOULD HAVE 12.6 VOLTS IF BATTERY FULLY CHARGED OR NEW.START THE ENGINE.WITH ENGINE IDLING YOU SHOULD HAVE 13.5 - 14.5 VOLTS AT THE BATTERY.IF NOT.ALTERNATOR NOT CHARGING BATTERY.BEFORE REPLACING ALTERNATOR, MAKE SURE DRIVE BELT NOT SLIPPING,CHECK ALTERNATOR FUSE,CHECK ALTERNATOR POWER FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE AND LOOSE CONNECTIONS. BEFORE DISCONNECTING NEGATIVE BATTERY CABLE TO MAKE REPAIR, TURN OFF RADIO FIRST TO KEEP FROM LOCKING IT OUT.
Jul 12, 2011 | GMC Envoy Cars & Trucks
Noma timer Type EMT757-UL instruction manual How to change the backup battery? I buy the timer from canadian Tire
The backup battery is a rechargeable battery located inside the unit and cannot be changed.
When the battery goes bad, the timer needs to be replaced.
Nov 03, 2010 | Hardware & Accessories
Canadian tire says tests fine. bought new battery,
Feb 12, 2010 | 1994 Jeep Grand Cherokee
Is Canadian Tire Mechanical truely overprice their
Every place overcharges so they can make money... $5-10 just to change wiper blades....
Canadian Tire though, is fairly decent in their prices, but then again, they've got amateurs compare to say a dealership...
Aug 09, 2009 | 1998 Ford Windstar
Nov 25, 2008 | Euro-Pro Shark Professional Upright Vacuum...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
