Question about Herstyler 3 Piece Clipless Curling Iron Set
Herstyler Light turns on, but does not heat up at all.
Ultima65 laminator wont heat
I would look for a fuse first, then it might be a heater problem
Jan 22, 2015 | Light Office Equipment & Supplies
My thermostat has both auxillary and emergency light on,both are green,what does that mean?
Aux light; This turns on when the auxiliary (second stage) heating is in operation
It turns on 1-6 F below first stage and is user adjustable
Emergency light; This light turns on whenever the emergency heat is manually selected
(Mode switch is in the EMER position)
While in the emergency Heat mode, the heat pump compressor is off,
and the emergency heat (same as the auxiliary heat) maintains the
set point temperature
Jan 22, 2014 | Computers & Internet
What is your favorite color
Black or maroon i dont like shouting colours
Apr 03, 2013 | Herstyler Trio Hair Repair Treatment Hair...
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
Microave does not turn and heat. the light comes
Replace the magnatron assy and the high voltage fuse.
Jul 10, 2009 | Microwave Ovens
Kenmore elite, im locked out and cant reset, no heat dry is not working to unlock get my wife off my back
I took off the lower panel and found some paperwork that gave option notes. under control lock it says "the Control Lock light is turned on and all keys of the keyboard are disabled wheneverthe control lock feature is involked by the customer. The Control Lock feature (and light) can be turned on or off by the costomer at any time by holding down the Air Dry option (water heat/ no water heat) key for 4 plus aeconds." Now I held it down (pushed) longer until the Lock light turned off, then If it doesn't turn off I did it to the no water heat and light turned off.
Hope this helps.
Mar 10, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Pilot light goes out when i turn on heat. pilot light is blue flame lights good but when try to turn on heat it clicks and goes out therefor heat doesnt come on
How long do you leave the pilot on before you turn on heat. The thermal pile will take 3-5 minutes to heat up before it will send a signal to gas valve. If thermal pile doesn't send signal then gas valve closes. You might need a new thermal pile.
Jan 18, 2009 | Rinnai Toyostove Direct Vent Heater:...
Herstyler 3 Piece Clipless Curling Iron Set Logo
76 people viewed this question
Top Herstyler Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Herstyler Health and Beauty Expert? Answer questions, earn points and help others
