Question about KUMYOUNG Audio Chip - SongsKaraoke System
Forgot password of my kumyoung proIIF, how can i reset to default
Forgot my wifi password
Many routers have a sticker on their belly with the default password.
Newer routers often have a reset switch to restore default settings.
(needs to be held down for 10-15 seconds). Most router makers host support websites; look up by model#. Good luck!
Mar 13, 2014 | Computers & Internet
Polycom hdx7000 forgot password
if you have a problem with remembering password for your laptop or computer . There is software that resets it you can either go directly to this software reset page here Reset Password Pro Reset Any Windows Administrator or User Password In...
or check this website out bout forgot password solutions How to unlock forgot Asus laptop or admin password Recovery of Windows...
if this is a phone then god save you.. reboot software
Feb 18, 2014 | Cell Phones
Forgot my password
Reset to default settings by pushing and holding the reset button for 30 seconds or so, release. This will reset to default settings. Reconfigure SSID and Security. You may want to write down the "password". A tattoo is a option, it's up to you.
Dec 30, 2012 | NetGear Computers & Internet
Forgot pasword
if you forgot the password you can reset the router back to default settings.
hold the reset button in with a paper clip for 30 seconds powered on.
then try and login using a browser to the default password is blank.
reconfigure the router to your settings.
Feb 20, 2012 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Forgot my administrator password fopr sony snaplab
both keywqords dont work. where can i reset to the default password
Mar 07, 2010 | Sony SnapLab UP-CR10L Digital Photo...
Cant login never had username or password if i did i forgot
Depending on which revision you have there are two possibilities
Default Username is: admin
Default Password is: password
Default Password is: admin
If neither of these work - you may have setup a new username and password and forgot - on the router you will see a reset point - reset the router to factory defaults and the username and passwords above will now work.
If this helped you then please help me and vote kindly, thank you.
Oct 14, 2009 | NetGear WGR614 Router
I forgot the security password
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user password
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Aug 08, 2009 | Acer Aspire 5580 Notebook
I forgot my password and login name
The following reset procedure will completely restore the default settings on the router including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the router powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
The default username is admin and leave the password blank.
Apr 05, 2008 | D-Link AirPlus DI-524 Wireless Router
Forgot my security password
do *2767*2878# this will reset it back to the default.
Feb 07, 2008 | Cell Phones
KUMYOUNG Audio Chip - SongsKaraoke System Logo
119 people viewed this question
Top KUMYOUNG Audio Players & Recorders Experts
Are you a KUMYOUNG Audio Player and Recorder Expert? Answer questions, earn points and help others
