Question about Chauvet Mini Kinta DJ Lighting Effect
Lights on mini kinta will not come on in sound activate mode
    New Friend:
That was exactly what it was! replaced the blue wire
Lights on mini kinta will not come on in sound act - lights-mini-kinta-will-not-come-in-sound-xlyburhdqdyh1c3cobh22su3-4-0.jpg
Posted on Jul 29, 2015
    New Friend:
5 wires go from circit board to light board . When in use constantly bending wires . One if not a couple of the wires broke from bending . Meter wires , see witch one broke . Install new wire .
Posted on Feb 03, 2015
2003 silhouette sitting in garage with key out and the doors keep auto locking???
A normal function of many modern "thinking" cars.
If you need it to remain unlocked you could leave a window open or leave a door on the first catch or leave the spare key in the ignition...
Dec 18, 2017 | Cars & Trucks
How do I fix Motor turns on but LED lights are not bright?
I had the exact problem, found a break in the brown/+ positive wire inside of the spring coil! This is why it worked when the motor moved into certain positions! I did a bit of a quick fix join and covered it in heat shrink insulation! It's now working again!
May 22, 2014 | Chauvet Mini Kinta DJ Lighting Effect
Replaced battery in my 1993 jeep grandcherokee limited now security system seems to cut fuel off seconds after engin fires
Here's some info as it sound like the theft deterrent is armed.
Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Feb 11, 2013 | Dodge Stratus Cars & Trucks
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
Hp mini 1000 does not seem to recognize my wireless network and the wireless network light will not come on. What do I need to do?
The front of the HP Mini 1000 Netbook has two switches and two small lights. The two switches are for power and wireless. The two lights are for hard drive activity and power. Both the power and Wi-Fi switch are designed exactly the same. They are flat with a little bump where a light is.
Check if the switch is on before trying to reinstall the driver.
Hope this helps!
Apr 13, 2011 | HP Mini 1000 Netbook
The batery on my 2003 mini went flat charged it up everything works (lights radio etc) it turns over but will not fire
Are you disciennected recently; its possible that you have activated the ANTITHEFT or PASSLOCK system. CHeck in the owner manual the procedure to disarm.
Mar 17, 2011 | 2004 Mini Cooper
How can I reset my Factory Alarm on my Jeep it wont run
Alarm Module Reset Procedure
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the lift gate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Jan 28, 2009 | 1999 Jeep Grand Cherokee
Chauvet Mini Kinta DJ Lighting Effect Logo
1,141 people viewed this question
Top Chauvet Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
gamehouse8888
Level 1 Expert
 steve
steve
Are you a Chauvet Event Planning and Celebration Expert? Answer questions, earn points and help others
