Question about Frigidaire Stove/Oven/Range Cooktop - 318079348
Ples389ech f20 when trying to bake displays f20 fault and beeps
Display panel dim
The display on my cooker started to dim until it finally went dark over a few weeks. Although a different make, I replaced the panel and everything is now fine. I was amazed how bright the new display was so it must have been dimming over a long period.
Nov 01, 2015 | Dacor Discovery ER30DSRSCHNG 30" Slide-in...
Trying to set time, got stuck on wrong time, can't bake my turkey F90 displays when I press bake and a loud steady beep comes on until I press Stop. so I need 2 questions answered thanks
According to your service manual page 9 an F-90 is maximum oven door unlock time exceeded.
Here is your SERVICE MANUAL
This video shows how to check the door locking mechanism:
This shows how the electric oven high voltage portion of your oven works:
Jan 01, 2011 | Kenmore Cooktops
I have the jenn air smoothtop model number jes8850bcs and the buttons on the front control panel are not working the bake or convect. Some of the buttons still beep and work but the oven portion does not....
I had the same problem... resetting the breaker fixed it for a while but it the problem always represented itself. Replacing the temperature sensor at the rear of the stove finally solved the problem. My problems started after doing a "self clean"
Oct 23, 2010 | Jenn-Air JED8430 Electric Cooktop
Bake and broil do not work
assuming that the worst case senario has taken place
first thing i would check is ensure i have proper voltage at the outlet, 120 from each side to ground
220 across L1-L2
the elements are the only thing on the range that uses 220v
if you know how to use a mutimeter
you can test both the elements
disconnect the range at teh breaker
take out the screws at the back wall that hold the elements in
pull out about an inch becareful they dont leave much slack on the wires
disconnect on element terminal and apply your leads your looking for continuity, your meter should beep
if not replace the element
if yes, let the element hang ensureing niether terminal touches anything, reconnect the other terminal
now turn the stove on bake if your doing the lower
turn you meter to ac voltage
you should read 220v
anything less than that, your problem is before that
Aug 02, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
JENN-AIR MODEL D156B Electric oven
Hi Sadirrd
Your problem (flashing F3) is most likely a defective temperature sensor.It may also be due to a open in the wiring harness connected to the sensor - unlikely but could be.
Post a rating for this solution
Regards
Nov 07, 2008 | Cooktops
Frigidaire Stove/Oven/Range Cooktop - 318079348 Logo
69 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
