Question about Tools & Hardware - Others
I need know where the spring go on a model HL-912
APS 912 worked for about 6mo - 1yr. Used with a
Sorry this is what the industry refers to as a throw away.
Sep 12, 2011 | Tripp Lite Lite APS INT 912 UPS System
Hi I am getting erro 912 on my HP Machine Please help me how to solve this. thanks
It sounds like a dll is currupt or missing.
Here is a link that may help to fix the error.
http://www.registryquick.net/runtime/Fix-Runtime-error-912-How-to-Fix-Runtime-error-912-50898.html
I hope thisd helped.
Good luck and have a fantastic day.
Jun 23, 2011 | HP Compaq Presario SR2011WM PC Desktop
Hello! am azwar my PC have a 912 problem. When ever i open My PC, it is show 912 error. how to solve the problem tell me. Thankyou..
Go to this WEB site for instruction on repairing a 812 error.
http://www.restoreguard.com/p/error-912.html?keyword=912%20error&gclid=COPBo5-sm6cCFUpypAodTD60eQ
Feb 22, 2011 | Computers & Internet
Error 912
Error 912 is often a critical system error caused by corrupt and missing registry data. This error should be fixed immediately to prevent further damage to the Windows file system.
You may download and install this fixtool straight to your pc:
http://www.cleanerrors.com/fix/error-912/
click download error 912 tool , save it on desktop and run it.
Once the tool is finished performing its application , try to restart the pc. If symptoms persist, contact your pc manufacturer.
Nov 15, 2010 | Computers & Internet
Paper is getting constantly jammed in printer and red light comes
It is pickup problem that is common in all HL MFC models based on this printer. This may be one of the reasons why they discontinued this model.
So, let's fix this:
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Mar 28, 2010 | Brother HL-2040 Laser Printer
Brother HL-4040CN Fuser Cover
Click this link below;
http://www.uninetimaging.com/newsletter/Brother_HL_4040_TN_115_Reman_eng.pdf
Sep 08, 2009 | Brother HL-4040CN Laser Printer
I have a remington precision hc-912 hair-trimmer. My 1/4 inch guard broke and I don't know where I can get a new one.
Use a precision screwdriver and pry the clip up. It is spring metal and will snap back into position upon reassembly. You will have to solder the battery in place. Works on all microscreen shavers supermesh and XLR.
Aug 31, 2009 | Remington Precision HC-815 Hair Trimmer
A sping from the paper tray poped out ..I dont know where to put it back...... the paper does not go up so it can be pulled and print and i hear click click .....model is Brother HL 2540 ...do I have to...
You may need a paper tray, about $20.00, that spring goes on the left and if it's off the tab is probably broken. Look in your manual for accessories and you should have the part number.
Jun 14, 2009 | Brother HL4040CN Laser Printer
We have a victor style medium cutting torch the cutting valve that is sticking open we were wondering if there is a spring in the cutting valve body.
Yes, but usually the valve gets dirty. I've tried to clean them with limited success. I've had torches cleaned at my welding supply house (M-G) for reasonable cost and good results.
Apr 10, 2009 | Victor ST900FC Straight Cutting Torch...
Tools & Hardware - Others Logo
42 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
