Question about Music
Chapter 20 why does dill get sick to his stomach
Hi , Do you have a full schematic for Mackie 32.8 mixer ?
http://www.mackie.com/products/32-8bus/#DOCUMENTS will have an owners manual- it has a block diagram in the last chapter.
Sep 18, 2014 | Music
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
Need korg ma-20 digital metronome owner manual
You can download the MA-20 user guide in word format from here:
http://tinyurl.com/cp6sddd
ciao
Bruno 0.5
Feb 22, 2012 | Korg Music
I have an epm 8 soundcraft mixer, epm 8 has no power switch just direct plug in to power supply, my problem is that it takes 7-20 minutes to turn on after we plug in the power cord..led power indicator no...
The E-8 mixer lights the power LED from the +15 volt regulated power...
The TYPICAL power supply might be similar to that on page 2 of:
http://elektrotanya.com/soundcraft_spirit-mseries_psu-digi-out.zip/download.html
Scroll down to "get manual" and click to download... ignore other dowload links on the page. You can use a free unzip program to unzip the RAR files.
Here is the E-8 schematics but missing the power supply... you know the drill... same as above:
http://elektrotanya.com/soundcraft_e8_mixer_sch.pdf/download.html
Since your unit has "morning sickness" I think you will find a BAD siolder joint in the power supply... The supply is very simple and it takes a trained eye sometimes to see the little gray line in the meniscus of the soldering at a lead that indicates a bad connection. Tracing the +/- 15 vp;ts should be an easy task. Pay particular attention to heavy components and the leads of the three terminal regulator chips... I would look at the +15 volt one closely...
Sep 06, 2011 | Soundcraft Epm8 12 Channel Mixer
I bought a second hand Fishman LoudBox Performer. The problem is that the Aux-in for the headphone doesn't work. So sick... What can I do? tnx
I don't understand your question. The "Aux in" is just that an input that goes to the power amp. Please note that the Fishman Loudbox does NOT have a headphone jack so don't be disappointed as there plain isn't a headphone jack on this unit. I would recommend that you get a small headphone amplifier for the purpose... or even go to a thrift store and get an old stereo system that has a headphone jack and use that.
Aug 01, 2011 | Fishman Loudbox Performer Amp Acoustic
When I insert a Compact Flash card into my TD-20, the green light above the CF slot blinks and the rest of the brain freezes up until I take it out. When I insert the card prior to power-up, I get a blank...
The card MAY be the wrong format for the unit. Also the maximum size for a CF card in this unit is 4Gb. Check that yours is not bigger than that. There has been SOME compatibility problems of flash drives... try a different brand.
Jul 16, 2011 | Roland TDW-20 EXpansion for TD-20 Drum...
Looking for a manual for the yamaha ex-20 piano
Hi jlinhardt,
Do you mean an Yamaha EZ-20 user manual?
This is an ez-20:
If that's the piano you want the manual for then here is the PDF version:
http://www.usersmanualguide.com/yamaha_audio/electronic_keyboards_(portatone_-_portasound)/ez-20
Click on the link to view, or right click and save as a .pdf to save the manual to your computer.
Hope this is what you are looking for..
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Yamaha Full-Size Keyboard
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
