Question about Network Engines, Inc. (SYS-NEI100-000) Firewall
Immobilizer in 1997 Honda Accord SE
My battery was dead and I tried to jump the vehicle. The horn began to sound and would not stop until I unhooked the jumper cable. Now nothing in the car works. It will not start. I must have engaged some type of security system. Can anyone assisst with how to reset this funtion?
  • ktickle Jun 14, 2009
    I have looked for the valet switch but cannot locate one.
  • 3,267 Answers
I think you will have to eventually dig out what security system you had installed and you may need to contact them right away because they are the only ones who know the code and reset modes........sodeep
Posted on Jun 14, 2009
  • 3,230 Answers
Look for a valet switch usually under the dash push it or switch it on and hold it while you switch on the car ignition switch this will turn off the alarm.
it will also help you to reingage your car.
Thanks
Horn wont work and gear shifter locked
is your battery dead the shifter cant move until you push down the brake.
Aug 21, 2013 | 1998 Honda Accord
My 2008 santa fe will not jump start and the alarms are sounding
Hey,, Your alarm system is malfunctioning.. This will do exactly what your describing above, Hopefully its not Factory installed,, That way you can locate it under the dashboard, and Unjack the wires running into it.. you will be fine then until you get it replaced.
if it was factory installed contact your dealer for the location of it if its and external box or connected to the cars CPU or built in.. If its built in you will need a new CPU and remotes. If its external your in luck, Get the location of it and unjack it..
by unjack i mean there is a harness connecting to it, unplug the harness..
nothing is wrong with your battery, The immobilizer system shut the car down. PS before you try any of the above see if you can disarm it with a spare remote.
Dec 28, 2012 | Hyundai 2008 Santa Fe GLS
My 2008 Accord just left me stranded at the store. Went to turn key and nothing...no click or anything, flashing dash lights. Initially when I tried to start it, my hand slipped. I was wondering if it...
I'd check the charging system.
Sounds like the alternator is not charging the battery...or...the battery is not holding a charge at least for very long.
Aug 27, 2011 | 2006 Honda Accord
198 honda accord ex if horns sounds, shorts out cruise control and brake lights. This happens when I manually sound the horn or the alarm does. Any ideas?
This is a tough one, if a horn itself was shorted, it wouldn't sound.Try unhooking both horns, and try to activate it from the steering wheel. If the brake light´s fuse still burns, at least you know that there is a short in the cabling leading to the horns. If the fuse doesn't trip, then one of the horns should be the culprit.
Aug 08, 2011 | 1998 Honda Accord
The battery of Honda accord 2009 was down and when the AAA person started to jump start it panic alarm was ringing . We tried to stop it with new keys, old keys , opened the doors manually and close, tried...
is the battery good? try unhooking the battery for ten minutes if it is and rehook and see if it does. this will reset the memory. the jump start may have been the problem hoping it was hooked correctly. if the battery tests bad replace it it could be the culprit. once you hook it up if the alarm sounds try disabling it with your remote then let us know what happens. hope this helps
Feb 04, 2011 | 2009 Honda Accord
Car stuck in park after pulling "stop horn" fuse on 07 Honda Civic. Horn was honking after jump starting it.
You will need to replace that "stop horn" fuse since it also feeds power to the stop lamps and the gear shifter solenoid, when you step on the brake pedal. Your best bet is to unplug the horn on the vehicle(to stop it from honking) until you can get it fixed. That way, you will be able to shift out of park to get it to a shop for repairs.
Oct 18, 2010 | 2007 Honda Accord Sedan
1997 honda accord se need to change vss,where
For 1997 Honda Accord 2.2L MFI 4cyl the Vehicle Speed Sensor - Location is located mounted on transmission.
OPERATION
The Vehicle Speed Sensor (VSS) is a magnetic pick-up sensor that sends a signal to the Powertrain Control Module (PCM) and the speedometer. The sensor measures the rotation of the output shaft on the transaxle and sends an AC voltage signal to the PCM that determines the corresponding vehicle speed.
TESTING
  1. Disconnect the negative battery cable.
  2. Disengage the wiring harness connector from the VSS.
  3. Using a Digital Volt-Ohmmeter (DVOM), measure the resistance (ohmmeter function) between the sensor terminals. If the resistance is 190-250 ohms, the sensor is okay.
REMOVAL & INSTALLATION
  2. Disconnect the three terminal connector from the vehicle speed sensor (VSS).
  3. Remove the fasteners that secure the VSS to the transaxle housing assembly.
  4. Remove the VSS.
To install:
  1. Install the VSS.
  2. Install the mounting bolts.
  3. Connect the three terminal connector to the sensor.
  4. Connect the negative battery cable.
Hope helps (remember rated this).
Jul 16, 2010 | 1997 Honda Accord
I came back from vacation my 2000 honda accord would not start battery is dead. I got a jump from someone. The car started right up but the horn continuously blows and wont shut off. Had to have car towed...
replace the horn relay;or the horn button on the steering wheel is grounded and energizing the horn. any maintenance involving the steering wheel can be dangerous becaus of the air bag. if you just want to stop the horn, remove the relay, probably located in the fuse box under the hood. check the manual for location, but if your state has a safety inspection it will need to be fixed before the inspection is due
Apr 14, 2010 | 2000 Honda Accord
I have a 1988 honda accord CX carb. It set for
Clean and tighten your battery posts and connections. Check the starter end and the ground too.
Jan 08, 2010 | 1988 Honda Accord 4 Door
Network Engines, Inc. (SYS-NEI100-000) Firewall Logo
143 people viewed this question
Top Network Engines, Inc. Computers & Internet Experts
David Payne
David Payne
Are you a Network Engines, Inc. Computer and Internet Expert? Answer questions, earn points and help others
