Question about RTO PasLode 900420 Impulse Framing Nailer
Fan runs all the time only way to stop it remove the battery and also does not fire
    New Friend:
  • 131 Answers
Need New switch.
-Jeff
Posted on May 07, 2014
2 Suggested Answers
  • 131 Answers
SOURCE: will not cycle after firing. must remove battery
You need a new circut assembly
Thanks,
Jeff
Posted on Jan 15, 2010
Acer aspite
That's not good. Something is getting way to hot. Do you experence the said issue with the battery removed? I would suspect the battery as well. A capacitor, PSU? I would take it to a qualified computer tech A.S.A.P. It COULD be a fire hazzard. Have you GOOGLED the problem or searched the ACER website for recalls of the battery? The fan will run as soon as you boot, but when the laptop gets to a pre determined temp, say hot, the fan spins at a faster rate. That would be normal. Also, are the fan and vents free of dust? Is the laptop getting sufficent air flow in and around the fan and vents? Does it happen at a certain time or place? Perhaps a Laptop Cooler?
Nov 19, 2012 | Acer Computers & Internet
Paslode impulse framing nailer , iv cleaned gun and oiled , the fan works etc . seems to only fire if i have fully charged battery ,once used for about five minutes it stops firing . only way to get it...
When it stops firing is the little light on the side of the handle green or red? If it is red then the battery is draining down too quickly. Either the fan switch has malfunctioned causing the fan to run all the time (I have seen this before) or you got either a faulty battery or charger.
Mar 05, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Gun was jamming up so i cleaned it now green light flashes but if i disconect wire put battery in then plug wires back in fan runs then stops and green light flashes again what could it be
the green light flashing means the tool is ready to fire. when the trigger switch is depressed or the safety activated the fan will run for a short time and automatically shut off. if the tool is not firing then it could be a loose connection of the circuit board or the spark unit. Let me know what the exact problem is and I will try and help further. Also check the expiration date on the bottom of the fuel cell.
Apr 16, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Dell 1501 on start up the fan runs for a sec then it stops.but dose not run. press the power button once more and it clicks off, I installed a new battery and charger. With no change.
This sounds like a motherboard issue, but first! remove the hard drive to see if the Dell logo comes up, if no! swap out your ram one at a time to see if it will fire up, if no change, dis-connect all external drives and the internal dvd drive, if you still can't get any life, "suspect the motherboard"
Apr 01, 2011 | Dell Inspiron 1501 Notebook
The problem of intermittent firing began some time ago. Now the gun will not fire at all. The gas bottle is full and the battery is fully charged. I disassembled and cleaned the gun. It subsequently fired...
what is the expiration date on the bottom of the fuel cell?? Also what were the condition of the o rings and did you relube with a good quallity oil. What I would do is remove the front assembly to expose the fan only and then insert a battery, pull the trigger and the fan should run for a few seconds, next there is a roller lever towards the top, depress it keeping fingers away from fan and again it should run for a few seconds, next depress and hold the lever and then pull the trigger and you should see it fire, repeat this several times, that will narrow it down to the spark unit/electronic assenbly or the cylinder.
Jan 09, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
02 grand cherokee fan keeps running after the engine is shut down
there is a fuse in fuse block underhood..but it sounds like a stuck cooling fan relay..is located on pass side front frame rail..you have to remove both headlamps and front bumper cover to access relay
May 07, 2009 | 2002 Jeep Grand Cherokee
Paslode fixing gun has stopped firing
Do you have gas cylinder in,if so is gas expiration date on bottom of cannister,change gas to current fresh date. Also open nose of nailer and see if a fastner has logged ,remove and push plunger pin back into body,be sure to remove battery during these tests.
Mar 19, 2009 | Tools & Hardware - Others
RTO PasLode 900420 Impulse Framing Nailer  Logo
41 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
