Question about Samsung Np300v5ai 15.6" Notebook - Intel Pentium B950 2.10 Ghz - Black - 1366 X
Laptop screen won't come on after using an external monitor
Used multiple monitors and chose to use external only now laptop monitor won't come on
SOURCE: problem with samtron 56v 15" monitor
IT IS REULATION COMPLIANT PLEASE CHANGE THE 7805REGULATOR IC NEAR THE MEMORY IC
Posted on May 12, 2007
  • 179 Answers
SOURCE: Using external monitor with Vista
the problem with adapters is they dont always pass all information thru,,try changing the screen resolution on the laptop down a little
Posted on Dec 01, 2007
drlalitv
  • 488 Answers
SOURCE: switch to external display
please ensure that the TV has a compatible input for connecting laptops etc..right click on empty desktop..go to graphic options u will see an option as output to.(if the tv is connected properly)
.hope it helps!
Posted on Nov 02, 2008
gherna1
  • 190 Answers
SOURCE: Screen Resolution problem
Different video cards offer different ways to deal with a user's screen. ATI, and others, for instance, offer a "virtual desktop", which does what you're describing. You get to the settings that control this feature from the Personalize->Display Settings menu options. Here you'll also find the different resolutions your video adapter supports. If the 1600 x 1200 resolution is listed, then I would remove the existing driver for both the adapter and the monitor, and reboot the machine. On startup, Windows will most likely detect the "new" hardware (actually, your existing ones) and will go through the process of finding the appropriate drivers for your adapter. Good luck!
Posted on Aug 16, 2009
  • 34 Answers
SOURCE: Screen not coming on
Typical problems with Samsung SyncMaster.
I just did this to a friends monitor as well, a different model and not much different in build. I think you might have 3 screws on lower back side of cover. Start your separation from the bottom of the frame.Your power switch will remain on the front frame while the wire will remain with the rest. Read the rest it will help.
HOW TO OPEN A SYNCMASTER2.gif 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start(different versions might have screws). The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable(if you need to remove it), two clips super close to where the sets of wires come around the housing and into the panel. Unhook the 4 plugs(blues and pinks)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
aae8fab.jpg The capacitors top-plain should be flat(not rounded) and there should be no color whatsoever coming through the top of the cap lines(google "bad capacitors"). The specs of the cap are on the cap. The 2 caps cost me $4.00. Now keep in mind there are hazards to this.Google them;)
Posted on Nov 18, 2009
I have a dell laptop that I want to add a second monitor to. My monitor is a HP L1755 and my laptop has Windows 7 Ultimate on it. I can not find a driver for this... any suggestions?
Hi there, if i read you correctly you are trying to connect external monitor on laptop. As you use old Monitor for this you can probably establish only VGA connection . For this you dont need any special drivers if you use VGA external connector on laptop. You just need to find out right combination on keyboard to activate external monitor to be activated or right click on desktop then properties and display option multiple displays. Of course when you manage to activate mode for external screen please use lower resolution like 1027*768 for second display aka monitor to test .Cheers
Sep 15, 2013 | Samsung 941BW LCD Monitor
Hotkey functions on Advent4211C
Connect the external monitor via VGA, (blue connector) or via HDMI.
Double click the Nvidia control panel, bottom right of screen.
Under Display heading:
Select "Setup multiple displays".
Now set display for primary (notebook display)
Set external display as the one you want to use.
Take care!
damnor01
Sep 12, 2012 | Advent 4211c Notebook
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Multiple vertical screens at startup (dell inspiron 4100)
Try connecting an external monitor to the laptop (15 pin VGA connector). If the display appears normal on the external monitor then you have an issue with your laptop's LCD display. If the external monitor also has vertical screens then your video circuit on the laptop has a problem.
May 19, 2011 | Dell Inspiron 4100 Notebook
How to set up multiple external monitors on a laptop
Since you only have one external monitor port, you need to use a video spillter, this will allow you to connect two or more external monitors.
NOTE: This video splitter will only give you duplicated displays. Please check the link below:
http://www.kvm-switches-online.com/video-splitters.html
Thank you!
Dec 29, 2009 | Toshiba Qosmio F45-AV412 Notebook
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
Cannot hook up lcd monitor as a multiple monitor. In Vista i use a vga cable to hook up the hannstar lcd monitor model hn199. when i plug in the lcd my laptop (an acer extenda) screen goes black and the...
Try the "Display Swap" button (usually a Fn key). Some of these have several choices each time they are pressed, e.g. Laptop Display, External Monitor, Both, and NONE!). Hope this helps. Ian.
Sep 17, 2009 | Computers & Internet
Secondary monitor from a Laptop
If your laptop doesn't automatically detect the external monitor, there will be a function key you need to press to activate the external monitor connector. It's often on the top row of keys, but different manufacturers put their function keys wherever they like. The key will normally have a marking that looks like a little monitor screen. Connect your external monitor, hold down the F or Fn key and press the monitor key when you find it. Usually the first press will turn on the external monitor and turn off the laptop screen, then the second press turns the laptop screen back on. Some brands or models may not turn off the laptop display, though.
Feb 10, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Dual (External) Monitors Hook Up for HP Pvillion zx5040us Notebook
Good day, Cyko!
Here is what microsoft has to say about that:
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/monitors.mspx
In reading through this, you'll note that they suggest that some docking devices, or a usb adapter for monitors may allow you to run multiple monitors.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Nov 30, 2007 | Computers & Internet
Samsung Np300v5ai 15.6" Notebook - Intel Pentium B950 2.10 Ghz - Black - 1366 X Logo
22 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
