Question about Creative Labs Nomad MuVo2 FM MP3 Player
Downloadfree fm radio - Creative Labs Nomad MuVo2 FM MP3 Player
There is no electrial retailer in bendigo that has fm aerial to suit this is why i am asking you
Make your own.
  • How to Make an FM Antenna: 8 Steps (with Pictures) www.wikihow.com/Make-an-FM-Antenna
    • 832K VIEWS
    2016-01-11 ยท How to Make an FM Antenna. Improving the reception of commercial FM radio (88Mhz - 108Mhz) can be done by you at home, simply by replacing the antenna ...
  • Simple FM Radio Aerial - Robert Sewell www.robertsewell.ca/yahoo/fmaerial.html Simple FM Radio Aerial A simple FM radio aerial can be made using about 5 feet of old 300 ohm TV downlead, an alligator clip and some hook-up wire.
  • Or try Jim
  • Antenna Installation Bendigo
    May 23, 2016 | Audio Players & Recorders
    My old unit stopped working;(worked perfect for many years) so I replaced with a new same model and I have bad interference and FM static. Sometimes the FM station overrides the express radio and all you...
    The very first XM radios, (SkyFi2, MyFi, Roady2) up until they were put in red boxes, had a VERY strong FM transmitter, so strong, that when Sirius was their enemy, they complained to the FCC and they made the FM transmitters real weaklings. So unless you have one of the first two batches of XM radios, the FM transmitters now are real junk and you're better off using an AUX input on the radio or a cassette tape adapter. Okay? Thanks.
    Mar 26, 2015 | Audio Players & Recorders
    Connecting mp3 car radio
    If you radio has an Aux input then you can connect a audio cable from your MP3 player to the Aux input on your radio.
    If your radio does not have an Aux input the you can use a FM transmitter device. Connect the MP3 player to the FM transmitter and tune your FM radio to the radio frequency on this FM adapter to listen to your audio book on your MP3 player.
    Check out these WEB sites fro FM transmitters.
    http://dx.com/c/car-accessories-799/car-audio-systems-707/fm-transmitters-players-710
    http://www.amazon.com/Coby-CA-745-Wireless-Transmitter-Cigarette/dp/B000OTF6G0
    http://www.popularmechanics.com/technology/how-to/gadgets/4307160
    Feb 05, 2013 | Audio Players & Recorders
    FM radio
    The FM Radio on your mp3 lets you listen to the radio (only FM stations)
    Aug 20, 2012 | Philips GoGear ViBE Digital Media Player
    How do you access the fm radio on a Samsung GT-C3300K please. The user manual only mentions the mp3 player. Thank you.
    To listen to the FM radio
    1. In Menu mode, select FM radio.
    2. Select to start the FM radio.
    3. Select Yes to start automatic tuning.
    The radio scans and saves available stations
    automatically.
    The first time you turn on the FM radio, you will be
    prompted to start automatic tuning.
    4. Control the FM radio using the following icons
    and keys:
    You can find the User Manual that show the FM Radio in this link. Look on Page 25 for the Radio Instructions
    Apr 21, 2011 | Samsung Cell Phones
    In my settings there is no fm transmitter selection available
    As far as I know, there is no transmitter in a Sirius Radio. I had an XM, and there was no selection for fm stations. They just figure you can tune the car radio to any fm station, in case you want to listen to fm. Hope this helps, but refer to your manual for details about what the unit can do.
    Jun 12, 2010 | Sirius Sportster 5 Satellite Radio...
    IBOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO...
    BOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO OPTIONAL BUT NOTHING IS PLAYING FROM RADIO
    Mar 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
    Bad reception fm radio signal
    usually batteries...am takes less juice.....battery strength will affect fm signal strength
    Nov 08, 2009 | GPX RDT4004SP AM/FM Radio
    STATIC/INTERFERENCE
    &R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
    • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
    • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
    Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
    Solution 2 - Cassette Tape Adapter
    : If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
    Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
    Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
    Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
    You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
    We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
    Sincerely,
    SIRIUS SATELLITE RADIO
    To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
    Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
    Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
    No radio in menu. only music. voice .settings .
    The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
    FM Radio (if applicable)
    The Sansa
    player includes an integrated FM radio for listening to live broadcast FM
    stations. Please note that the FM Radio function may not be available in your region.
    Listening to FM Radio
    To listen to live broadcast FM station, follow these steps:
    1. Select FM Radio from the Main Menu.
    2. A radio frequency menu will appear.
    3. Press |<< or >>| to adjust and search for the desired frequency, or select
    preset by pressing Select.
    4. For fast search, press and hold the |<< or >>| buttons.
    Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
    Creative Labs Nomad MuVo2 FM MP3 Player Logo
    18 people viewed this question
    Top Creative Labs Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
