Question about AccuWeather ACCU WEATHER Free for iPad
How to delete locations i have added - AccuWeather ACCU WEATHER Free for iPad
Delete ad in olx
I am assuming you placed the advertised and do not require it anymore. You must know your olx login details to delete the ad.
Follow this youtube video.
How to delete an Ad on olx in
But if it is an ad placed with your details by someone else who you do not know (fake ad) then send email to support@olx.com with link of the ad and request removal.
Aug 07, 2014 | 1995 Opel Kadett 200is
How do I delete a channel I set as a favorite?
Google the model number with the word manual after it to locate the owners manual if you do not have it.
Most sets in the menu when you call up favorites allow you to click with the remote on the one you want removed or added and to delete or add it to the list.
Mar 14, 2012 | Toshiba Televison & Video
Hi... i have added one pik of my friend in folder 'my photos' (phone memory).., 4 making that picture as his caller id pik., now i have removed dat picture from caller id but when m deleting the...
Give this a try. Plug in your mobile phone to the pc. Once ask on how do you want to use it either sync,mass storage or com port just select mass storage. Once selected go to photos folder where the picture that you want to delete is located. Just drag the pic to a different location like c: drive or documents and try deleting the picture from there. Once the picture is removed it would not appear anymore on your contacts.
Mar 11, 2011 | Samsung Lands Phones
How to briefly disconnect ad aware (anti-virus) and download adobe flash drive to my computer
hi terrye, i am happy to help you , just follow these steps you can able to remove ad aware anti viurs
Manual Removal of AD AWARE
1. Click on "Start," then choose "Programs." Click "Uninstall ad-aware." Allow the computer to uninstall the software. If the program does not successfully uninstall, uninstall the program using the control panel.
2. Click on "Start," then choose "Control Panel." Click on "Add/remove programs." The programs that are listed on your PC will be displayed. Choose "ad-aware se." You will be asked if you want to remove the application and all of its components. Choose "Yes," and allow the program to uninstall.
3. Locate the ad-aware program folder and un-register it by clicking on "Start" then "Cy computer." Double-click on "Local Disk." Locate the "Program Files" folder and double-click on it. Locate the "Lavasoft" folder and double-click on it. Locate the "ad-aware" folder and double-click on it. Next, double-click the file "unregaaw.exe" to un-register the file. Next, delete the entire Lavasoft folder.
4.Delete any Ad-Aware SE program icons that may be present on your desktop. Remove the Lavasoft folder located in your documents and settings folder. Navigate to the folder by clicking on "Start," then "My Computer." Double-click on "Local Disk." Locate the "Documents and Settings" folder and double-click on it. Locate the folder labeled with your computer user name and double-click on it. Double-click the "Application Data" folder, choose the Lavasoft folder and delete it. Reboot your PC.
ADOBE FLASH PLAYER
its not much hard to install adobe flash player , just copy and paste the link below
http://get.adobe.com/flashplayer/
after page got loaded click this button Download now
your flashpalyer will start to download, to make it more easy i will add video just check it out
utube.png You-Tube video "dxxYHlJ-7W8" placeholder Good luck ! if you think your problem solved don't forget to rate
Jan 01, 2011 | Dell Inspiron 530s Desktop Computer...
My compaq mini 110 was infected with THINK POINT VIRUS. i downloaded a malware scanning program which seemingly worked for about a day...with an abundance of pop ups and self restarts. as i researched...
Hello
The re-installation of windows is however recommended, but you can try with follwing procedure to remove Think point Virus:-
1. Restart your computer in SafeMode - After Power-On the computer, just before Windows start, press F8 - From the selections, Select SafeMode
2. End ThinkPoint Process - Press Ctrl+Alt+Del from the keyboard to open Task Manager - Go to process Tab - Select 'hotfix.exe' and click on End Process - Close Task Manager
3. Remove Registry entries that the threat added. You MUST BACKUP YOUR REGISTRY FIRST. - Click Start > Run - Type in the field, regedit - Navigate and look for the registry entries mentioned above and delete if necessary
4. Delete malicious files that the threat added: - Base on the given location above, browse and delete the file - If no location is given, click Start>Search> and search for the files. - If cannot be deleted, press Ctrl+Alt+Del to access Task Manager, see if the file is running in the process. If it is, select the file and click End Process. Perform file delete again.
5. Scan computer with Antivirus Program - Update antivirus program - Scan computer and delete all detected threats.
Hope it will helps, if so do rate the solution
Good Luck
Dec 15, 2010 | Compaq Computers & Internet
Delete all songs
Automatically adding and removing songs and playlistsWhen iPod is set to automatically sync all music with iTunes (default setting), songs and playlists that are added or deleted from your iTunes Library will also be added or deleted from your iPod when the iPod is connected and synced with iTunes. If your iPod is set to only sync certain playlists automatically, songs are added or removed from the iPod when they are added or removed from the playlists in iTunes that are synced to iPod1. For more information about automatic syncing with iPod, see the iPod Tutorials and this article.
source: http://support.apple.com/kb/HT1855
Oct 31, 2009 | Apple iPod nano
How do i clear most recent location
according to Moto customer support, only way to delete is adding more locations and then 29th location will be deleted .
Aug 10, 2009 | Motorola Mobility MOTONAV TN20 GPS...
I deleted my cyberlink youcam shortcut in my compaq v3700,however it said it does not reinstall the program but just deletes the shortcut which is not found in the recycle bin too.. how do i go about with...
Sir,
Right click at desktop go to New->shortcut->it ask the location of which the program is stored. click the location C:\ of that software. It will be created the shortcut
Thanks Good luck
Aug 10, 2009 | Acer Aspire 5100 Notebook
Winplayer.exe and autorun.inf virus
you probably have the virus on your registry and that is a tough one. it depends on the type of virus you have, it may not allow you to install an anti-virus, but you can give it a try. download ad-ware or malwarebytes from the internet, the free version and enable all the settings. start with the malwarebytes its good for problems like this and see if it can get the virus out.
Jun 23, 2009 | Microsoft Windows XP Professional SP2
AccuWeather ACCU WEATHER Free for iPad Logo
65 people viewed this question
Top AccuWeather Apps Experts
Erin Wood
Erin Wood
Are you an AccuWeather App Expert? Answer questions, earn points and help others
