Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
A
Anonymous Posted on Mar 17, 2014
Where is the shift key - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Jun 16, 2014
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442394
Points
622693
Near the upper-left corner of the keyboard, marked "2ND".
Hey how do i access the keys ie brackets
Hold down the Shift Key while pressing a bracket key.
That is press them in combinations like :
Example: Shift key and ( key
Shift key and ) key
Shift key and [
Shift key and ]
Actually you can use the Shift key in combination with any key to access the secondary character on keyboard.
How to activate/deactivate the alternate keys(blue font) on keyboard
Sharing my experience that my windows works properly from site www.vanskeys.com use a key to share you. Hope can help you.
1helpful
3answers
Which is the shift key
Hi,The 'SHIFT' key is usually placed just below the 'Enter' key on standard keyboards.Here is a picture.
@ key is not working when i press the shift key and @ its only giving me #2
Then your shift key may be faulty, try using the shift key on both sides of the keyboard to do this. If it still doesn't work then it means that your shift keys are fine its just the secondary functing of the "2" key that is faulty.
1helpful
Where can i find a printable page to print all the controls and functions on lock on moder air combat please help
Scroll Lock Key nearest air target Alt + Scroll Lock Key center-of-view air target Shift + Insert Key next air target Shift + Home Key previous air target Shift + Scroll Lock Key nearest ground target Ctrl + Num Lock Key center-of-view surface target Shift + End Key next surface target Shift + Delete Key previous surface target
MISSION EDITOR Ctrl + N Key create a new mission Ctrl + O Key open an existing mission Ctrl + S Key save the active mission to disk Ctrl + Shift + S Key save the mission under another name Esc Key delete the current selection on the map Delete Key delete the current selection on the map Ctrl + Shift + C Key assign the active mission to a class and protect it with a password Ctrl + Shift + D Key declassify the active mission Ctrl + H Key hide or show specific objects on the map Ctrl + 1 Key return the map to the default magnification level around the crimean peninsula Ctrl + + Key magnify the map by a factor of 2 Ctrl + - Key scale the map down by a factor of 2 Ctrl + O Key take the view down to a very close level Ctrl + V Key magnify the map to a regional view centered on the selected object Ctrl + B Key view and edit the mission briefing Ctrl + D Key view a debriefing when a saved mission is loaded Ctrl + F Key start the current mission Ctrl + N Key begin a network multiplayer session Ctrl + M Key chat with other players during a multiplayer session Ctrl + R Key start the mission and record a video sequence Ctrl + P Key play back the last recorded video sequence Ctrl + V Key start the video sequence and enable its editing Ctrl + Shift + F Key specify failures that may happen to your aircraft Ctrl + Shift + W Key specify meteorological conditions Ctrl + Shift + E Key open encyclopedia Ctrl + Shift + O Key open options screen F1 Key help F2 Key keyboard command list
1helpful
2answers
SHIFT KEYS NOT WORKING PROPERLY
Please try to deactivate the Fn (function) key. That will help you get rid of your problem. Press Fn key + Numlock key once and try again. You can also try pressing the Fn key once and type letters in any word processor program with the key combination everytime you press the Fn key once. E.g. open the notepad, press Fn once and after that press ) with Shift.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
3answers
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
2answers
IBM R52 laptop shift key deactivated - pls help
you might have accidently disabled 'stick keys' it is a short cut that is activated is you press shift 5 times
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
