Question about Onkyo TX-DS989 Receiver
Doesn't recognize remote control - Onkyo TX-DS989 Receiver
Windows 7 doesn't recognize remote
Do you have the software disc for the remote? If not, go to the Logitech website and download it for your model. You might need drivers from the program to work with Win 7. I'm running mine without any problem.
Apr 07, 2013 | Logitech Harmony 550 Remote Control
New remote doesn't recognize TV, only BD player. can it be programmed?
The TV function on your remote probably only controls a Sharp TV
Dec 02, 2012 | Televison & Video
VOLUME CONTROL ON TV REMOTE CONTROL DOESN'T WORK
Hello
Your remote control needs cleaning. Just go to this link and see the details. OK.
http://www.fixya.com/support/r10192276-cleaning_remote_control_handsets
Nov 17, 2011 | Televison & Video
How do I get my att&t u-verse remote control to recognize my 51 inch samsung TV?
The remote can't recognize the tv, it doesn't have that capability. If you want to use it to command that tv you must program it accordingly. Basically you must introduce the code that corresponds to the set of commands that your tv uses - if they are present in the remote.
This is the programming procedure:
1 - hold down the TV button on the Uverse remote. As you are holding the TV button, press and release the OK button. You know you have done this right when all the mode keys flash twice.
2 - Find the 4 digit code for your device in the User guide that was given you when the Uverse was set up, or online at
https://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf
3 - At this point, the TV mode button should flash three times. Try to turn the TV off by pushing the power button. If it does not turn off, try a different code. If it turns off then turn it on with the remote and test the other buttons. If they don't work then try a new code.There are a lot of codes for Samsung in there, try them all until you find the one that has the best compatibility - most buttons that can be used.
4 - If none of the codes for your device work, try manually searching for a code. Go back and repeat steps 1 and 2. Then enter 922. Hold play as the remote cycles through various codes. When your TV turns off, push enter to memorize it. This generic code will provide just a basic control, if you really need full control then you will need another remote.
Jul 02, 2011 | Televison & Video
I am trying to use RealPlayer software to burn my DVD's and even though they play on my windows media player and Real Player on my computer, my Emerson DVD player doesn't recognize them. How can I...
U can't because they're not compatible softwares.Buy a DVD's burn software and install and burn DVD's that way.Will be compatible 90 95% of the DVD players out there in the market.
May 12, 2011 | RCA Universal Remote 3 Device Remote...
Remote control not recognizing codes
Codes for many of our TVs can be found at InsigniaProducts.com. For the Blu-ray player, we recommend using your universal remote's scan or learning feature.
Apr 28, 2010 | Hughes HRMC9 Remote Control
890 won't recognize a know =n good battery
Probably your remote is dead. I wuld call Tech support for a warranty replacement if you are still in the 1 year warranty.
Nov 21, 2009 | Logitech Harmony 890 LCD Remote Control
PS3 not recognizing controller or remote
More information please. Have you got your PS3 factory reset?
Feb 02, 2018 | Sony Playstation 3 (PS3) Console
NFocus ScreenPlay 61md10 61 does not recognize remote
on the universale remotes it tells you on the back of the package what tvs it will and wont work with.
Oct 20, 2007 | InFocus ScreenPlay 61" Rear Projection...
Onkyo TX-DS989 Receiver Logo
27 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
