Question about Ocusoft Lid Scrub Original Eyelid Cleanser -- 30 Individually Wrapped Pre-Moistened Pads
OCUSOFT LID SCRUB VS OCUSOFT LID CLEANSE - Ocusoft Lid Scrub Original Eyelid Cleanser -- 30 Individually Wrapped Pre-Moistened Pads
Does extreme fit 180 cleanse and apple cider vinegar help u lose weight?
LOL>>>> if that all you eat or drink... its will cleanse you, help you lose weight.. and maybe even kill you!!!!
There is no substitute for proper diet, in moderation, and regular daily exercise...sorry..
Sep 11, 2017 | Dishwashers
How do I hook up the upholstery attachment on a Hoover Spin Scrub 50?
To connect the upholstery tool, first remove the clean water tank by pressing down on the handle and pulling the tank forward. Remove the hose from the storage rack. Press down on the handle release lever and lower the handle to the ground. Unlatch the back part of dirty water tank and remove the lid. Pull the dirty water tank's front panel up about an inch and rotate the panel to parallel with the floor. Replace the panel with the converter and slide it halfway down until it is firmly in place. Pull the collar on the connecting tube towards the tube so that the black tabs are fully extended. Open the door on the hood labeled Stair/Upholstery cleaning connection and press the round solution tube onto the round projection. Press the collar firmly to ensure that the tube is connected. Replace the tank in a hinge-like manner and place the lid under the tabs on the front of the tank. Rotate the lid down onto the tank.
Now slide the upholstery tool on the connector of the hose until the tab locks into place.
The manual for the Spin Scrub 50 is available on the Hoover product page: http://hoover.com/products/details/fh50044/steamvac-spin-scrub-50-carpet-washer-with-tools/ . The direct link to the manual is http://hoover.com/file/1195/ . The directions are on page 14-15.
I hope this helps.
Oct 19, 2015 | Hoover Vacuums
Will not download
are you sure you downloaded the correct version i.e. 64 vs 32 bit?
Mar 24, 2014 | Computers & Internet
Won't stop beeping
you could try jamming a small bit of dowel or something into the hole where the lid pushes onto the little trigger..won't be a great solution without getting a replacement lid.
Mar 24, 2014 | Cuisinart DGB-500 Coffee Maker
We have a pin trap problem. The outer cover comes off exposing a plastic white facing that will not budge. There is constantly a rotten egg smell coming form the washing machine. I've drained the hose...
Here's How:
  1. Exterior
    Wipe down the exterior of the washing machine with vinegar or your favorite all-purpose cleaner.
  2. Tub
    Pour two cups of vinegar or lemon juice into the tub, and run the washing machine through a complete cycle on the hottest setting to remove odors, stains and detergent build up.
  3. Lid/Door
    Scrub around the edge of the lid/door with vinegar to remove mildew and detergent build up.
  4. Bleach and Fabric Softener Dispensers
    Remove the bleach and fabric softener dispensers, and scrub them in the sink. Then, dry them thoroughly and return them to the machine.
Tips:
  1. To prevent mildewing, leave the lid open after you finish a load to allow the washing machine to dry out.
  2. Commerical fabric softeners leave build up in the machine. of choice, and the inside of your washing machine won't need to be cleaned as frequently - if at all.
May 17, 2011 | Asko W6021 Front Load Washer
I cant get my foundation pump dispenser to pump out the fluid
You may try using a cleanse off oil to clean your liquid foundation pump. Pour some cleanse off oil into a clean container and soak your pump therein for 15 to 20 minutes. Then, try to use a stick (preferably the stick of a q-tip) to take off excess foundation left in the pump's tube. Lastly, using the foundation pump, try to pump the cleanse off oil from the container.
Apr 20, 2011 | M+ Mac Cosmetics Liquid Foundation Pump...
I have a mitsubishi vs-60607. The outer screen was damaged during transport.. First, does the outer screen have a name or part number?Second can it still be purchased?
gona be hard
try the old white tooth paste trick
abit of soft scotch/rag with white toothpaste - scrub easly
should get it better
Dec 29, 2009 | Mitsubishi VS-60607 TV
Ocusoft Lid Scrub Original Eyelid Cleanser -- 30 Individually Wrapped Pre-Moistened Pads Logo
13 people viewed this question
Top Ocusoft Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Ocusoft Health and Beauty Expert? Answer questions, earn points and help others
