Question about LG Washing Machines
Wm2301hw controller error - LG Washing Machines
I have an LG WM2301HW front load washer keeps turning on by it self with door open.
Check whether the door switch is not jammed in the closed position. It closes an electrical circuit when the door is closed, so if it is stuck in the "closed" position, it is giving a signal to the main control board that the door is closed when in fact it is open.
Jun 18, 2017 | LG Washing Machines
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
Oct 24, 2015 | LG WM2301HW Front Load Washer
I'm getting flashing error code on washer. It's flashing " DE" Thanks! Sam Singleton
If you've already tried to unplug the machine and that didn't correct the issue, the door latch assembly will need to be ordered and replaced to fix the issue. The latch assembly is just not reading that the dor is shut properly even though it is.
It doesn't matter if it appears to work or not--it's not giving the correct signal to the control board after it locks to tell the control board that the door is latched and shut and ready to start the wash cycle. This is why you need to replace the latch assembly.
Nov 07, 2011 | LG WM2301HW Front Load Washer
Front of wash displays UE code
Hi
Code UE is an unbalanced load error, usually shown when there is a very small load where the machine cannot redistribute the weight to balance it .Either the load is too small, the appliance is tilted, laundry is gathered to one side, or non-distributable things have been put into the machine.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | LG WM2301HW Front Load Washer
Displaying oe
LG's 'oe' stands for Open (door) Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 25, 2011 | LG WM2301HW Front Load Washer
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
Water continues to fill the tub even when the machine is off! Our water supply valve is the only way to make it stop filling!
This is symptomatic of a malfunctioning (not closing completely) water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 29, 2011 | LG WM2301HW Front Load Washer
Error code LE causes
This will cause the washer not to spin. This is most likely due to a bad Hall sensor, or the Stator assembly. You can replace the hall sensor, or the Stator, which comes with the Hall sensor.
Mar 07, 2011 | LG WM2301HW Front Load Washer
My LG WM2301HW is not putting water into the washer. Please advise.
the inlet valve is mechanically jammed shut so when the controls tell it to let water in it cant because the valve is jammed shut.need a new valve.
Jan 11, 2011 | LG WM2301HW Front Load Washer
I recently purchased an LG WM2301HW washing machine. I was wondering if this particular unit automatically controls the temperature of the water on a particular cycle or if the warm water needs to be...
page 22 of the user manual states that warm rinses are regulated at 86F (30C) it states that there is a heating element as well to boost the temp to normal hot water temperatures (90-100 C)
Apr 11, 2017 | LG WM2301HW Front Load Washer
Washing Machines Logo
12 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
