Question about Jandy Aqualink Rs4 One Touch Control System Control System
Jandy chlorine generator - pda reads 'general fault' filter pump and my reading is at 3800 should be between 3300 and 3500. What can I do on a Sunday - water is murky.
    Top Expert:
  • Jandy Master
  • 8,915 Answers
Clean or replace salt sensor make sure cell is clean also
Posted on Jan 30, 2016
4 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: aqualink rs6 program canceled and does not recognize chlorine gen
Trouble shooting guide
Posted on Feb 26, 2009
SOURCE: Aqualink Chlorine Generator not producing any chlorine
It shounds like that you might have a mustard algae issue. It feeds on chlorine. It is possible that your unit is producing chlorine but the algae is consuming it as fast as it can be made. You will need to do a shock treatment and use an Algae 30. It could be something else, but this is likely. You can google mustard algate treatments and read up on it to see if you have other symptoms.
Posted on Aug 04, 2009
  • 3 Answers
SOURCE: jandy pda 8265 not working
Have you replaced the 9v battery in the control box recently?
Posted on Jun 11, 2011
Jandy Hand held reads the wrong wrong pool temperatrure
the chlorine generator is giving you a correct readout of your pool temp. however, your water temp sensor is bad. if you look at your filter pump, follow the pipe coming from the top of the pipe, until you see a metal clamp. withthe system off, remove the clamp and pul out the sensor from the pipe and replace with a new 10k ohm temp sensor. NOTE: Older Jandy systems used black temp sensors, the new sensor may be slightly larger. use a masonry drill bit to bevel the old hole out for the new sensor, and replace the wires.
Feb 17, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have a jandy pda and have no idea what the message that its displaying means. This is our first pool and the owners manual has not helped! It says aqua pure 100% salt 4500 ppm, check aqua pure high salt...
it is showing your status aqua pure is set at 100% salt is at 4500 parts per million which is too high to operate should be between 2700 and 3400 to work properly you need to drain some water out and add fresh to dilute the salt general fault is because salt level is too high it is showing your filter pump and extra aux is on go to the equipment on on main screen it will give you a list of all your equipment any questions send me more info
Sep 20, 2013 | Jandy Aqualink Pda Ps6 Wireless Handheld...
General fault
general fault is because your chlorine generator isnt working
Aug 19, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy PDA not showing water temp
sounds like a loose wire on the red 4 pin connector to get water temp filter pump must be running lost of times closing crews disconnect that stuff if that doesnt work give me more info
Mar 02, 2013 | Jandy Aqualink Pda P8 Wireless Pool or Spa...
How do I fix a PDA with general fault message? What can can suh a reading?
general fault is the aqua pure either not enough salt or too much salt check salinty or the sensor or cell needs cleaning or replacing
Nov 05, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
My remote shows aqua pure as a general default. I have cleaned cell but it did not change. System is not creating clorine.
In this case I would call the Jandy technical support. If it says it is in general fault then it means it will not generate chlorine. I hope this helps.
Aug 09, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
2 problems one a reading of general fault the
How are you increasing the orp if not with chlorine?
ORP is not a direct chlorine reading and can be misread for a number of reasons, if your alkalinity, ph, cyanuric acid, or TDS levels are out of control, the ORP reading on any controller will be mute. These controllers manage ph and chlorine only (typically), but all the other chemicals and water treatment rules still need to be handles by the user.
It is also possible that your orp probe has gone bad. The most important thing to have dialed in is the pH, otherwise you will never get a correct ORP reading, as they are only accurate when in between 7.2-7.8 pH value.
Also, if you cant raise the pH above .5 no matter how much chlorine you add, you might just have old contaminated water, if the TDS and the CYA are extremely high, you will see this scenario.
Apr 11, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My jandy pda won't pickup aquapure salt generator
go into system set up youl see aquapure move it from 0 to at least 5% and it will show up that is if the red 4 pin is connected in the aqualink
Jul 28, 2010 | Jandy Aqualink Pda Ps8 Wireless Handheld...
I have message on pda "check AquaPure general fault"
SALT GENERATOR IS NOT WORKING OR SENSOR ARE BAD SEE AQUAPURE READING FOR CODE YOPU MAY HAVE TO CHAGE IT
Dec 06, 2009 | Jandy Aqualink - Rs32 One Touch Pool / Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
253 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
