Question about Shark Navigator Freestyle Stick Vacuum - White
First it wouldn't turn off now it will not turn on
Is it possible to vacume water with the miele slaris turbo plus?
I wouldn\'t attempt that unless it says you can do that in the manual. Use a steam cleaner. They are made to suck up water.
May 18, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
Miele s500 wouldn't turn on?
try pressing the reset button ,this link is the manual and will explain about filter reset,
http://www.instructionsmanuals.com/u2/pdf/aspiradoras/Miele-S500-en.pdf
Apr 18, 2013 | Miele Vacuums
Is there a trigger handle to turn off and on
no betty, stupid bit of kit imo, no operating switch, just on/off at the switch, which heats the water up. i measured 500ml of water heated using my kettle, put the top on, switched on, and waited. first time the steam didn't come out of the nozzle, so i removed the end and cleaned the nozzle with water, blew down the end from the big end, and replaced it, steam came out. big grumble though, the steam coming out is not that warm, don't advise you to, but i directed against my fingers, it's only hot at the exit of the pointing bit, used it to try and clean floor tiles and grout, complete waste of time. i wouldn't advise anyone to buy one.
Dec 11, 2011 | Tristar SB Steam Buggy Vacuum
I was vacuuming for about 2 minutes and turned it off. Cleaned out canister and when I tried turning vacuum on, it wouldn't start.
I'm glad to hear you were able to identify the extension cord as the cause of the fault. However, if you happen to experience any difficulties with your Dyson cleaner, you can get in touch with us directly by calling free on 08002980298 (UK), or 1866MYDYSON (US). Our experts will be happy to provide the support you need to help resolve your issue.
Kind regards,
Jack
Dyson Online Customer Support
Sep 18, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
6 yr old Aqualisa shower working perfectly well. But turned itself on last night. No light showing on dial/on switch. Wouldn't turn "off" for me. Ran for 15mins and then switched off!
Good Aternoon lrmulholland,
Do you know what model Aqualisa shower you have or are you able to take a photo of it for us? That would be very useful.
Kind Regards,
The Aqualisa Team
Sep 07, 2011 | Vacuums
It ran fine then starting cutting out and then wouldn't turn on at all. No blockage in any of the hoses.
It sounds like you have a faulty switch or a bad power cord those would be the first place to start troubleshooting
Sep 05, 2011 | Vacuums
I was vacuuming tons of powder up, a powder that kills fleas,its a real fine powder that clumps easy, and i emptied the canister and replaced it back on/into the vacuum and then it wouldn't power...
We wouldn't recommend using your Dyson for picking up large amounts of very fine powder, because it's not designed or tested for this purpose. I note you've already washed the filters, but you might want to view the video demonstration embedded below to check you've done so correctly.
If you've done this and you're still having difficulties, please get in touch with us directly so we can resolve this for you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Jul 26, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My volta pet lover vaccumm won,t **** up the dirt and fluff off my carpet. It is also very hard to push when it is turned on.
The product is a load of rubbish. I wouldn't bother to fix it. It does not perform as desired. Scrap it or use it as a boat anchor!
Feb 16, 2011 | Electrolux EL1000A2 Pronto Bagless Stick...
Shark Navigator Freestyle Stick Vacuum - White Logo
120 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
