Question about Stanley Black & Decker Bostitch B380HD Heavy Duty Stapler
HOW DO i REFULL THE STAPLES - Stanley Black & Decker Bostitch B380HD Heavy Duty Stapler
What.size staples needed for arrow fastener ct50
Product description
Product description
2750-1378 Features: -Revolutionary design with ergonomic handling.-Easy release drop in loading channel for staples.-Battery contains an easy to read LED charge meter.-Built-in safety switch prevents accidental firing.-Adjustable staple drive with depth of drive dial.-Light weight design for prolonged stapling tasks.-Can use T50 type 1/4'' staples (2750-0719), T50 type 5/4'' Monel staples, T50 type 5/16'' staples, T50 type 5/16'' Monel staples, T50 type 3/8'' staples, T50 type 3/8'' Monel staples, T50 type 1/2'' staples, T50 1/2'' Monel staples, T50 type 9/16''.-staples, and T50 type 17/32'' Ceiltile staples. Includes: -Kit includes case, charger, and tool. Specifications: -10.8 volts.
staples needed for arrow fastener ct50 Google Search
Jan 11, 2018 | Arrow Tools & Hardware - Others
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
Which swingline staples be used in a Bostitch B8E Electric Stapler
Absolutely essential you only use specific staples.
Use only:
B8 PowerCrown 1/4" Premium Staples (STCR21151/4)
-or-
B8 PowerCrown 3/8" Premium Staples (STCR21153/8)
Use the 1/4" staples for up to 20 sheets and the 3/8" for up to 45 sheets.
Sold at Staples, Amazon, Office Max, etc.
About $4/box of 5000.
Mar 25, 2014 | Stanley Bostitch B8E Electronic Stapler...
Loss of power steering and white smoke from engine
for the powerstearing check the oil and refull when nessesary,turn engine on turn 5 times hole the way left and 5 times hole the way right.
check level oil again refull when needed.the white smoke on that spot
you say can leak from diesel.
Jul 26, 2012 | 2003 Mercedes-Benz C-Class
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
Apr 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
Phaser 8560n printing greenish instead of cyan
Just shut it down for about 15 minutes and turn it back on. Every long warm up the machine will **** out the old ink and refull. Some of those odd sounds is a compressor emptying the print head.
You may not get the true blue you want. That is a shortfall on that machine, I have battled getting a greenish blue tint on that product.
Have not received a good answer from engineering. Frustraiting.
Sep 09, 2008 | Xerox Phaser 8500/DN Printer
Stanley Black & Decker Bostitch B380HD Heavy Duty Stapler Logo
49 people viewed this question
Top Stanley Black & Decker Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Stanley Black & Decker Office Equipment and Supply Expert? Answer questions, earn points and help others
