Question about Dell 1700n Laser Printer
Toner Notice Each time I print a notice comes up and tells me the amount of toner I have left and a choice to order supplies. I have to X it off but it slows down the operation of the printer and is very annoying. Any way to turn it off? Thanks. M HuguesMaurice River Township School District
  • 1,601 Answers
Re: Toner Notice
Remove the toner cartridge and firmly shake it from side-to-side and front-to-back several to use the
remaining toner, and then reinsert it and continue printing. Repeat this procedure multiple times until
the print remains faded. When the print remains faded, replace the toner cartridge
Posted on Nov 16, 2007
0 characters
3 Points
How do i toner low error remove
Dear Ateeq
the printer has unique CRUM ID chips attached to drum unit and toner unit. These are operate on RF power.
The toner empty can removed when you install a genuine toner cart. and its capacity is 20000 pages. but still you can print 10% of its capacity,i.e. 2000 pages from the time of first notice of toner low.
Feb 28, 2015 | Samsung SCX-6345N Printer
Laser printer has dark cast to entire page, prints ok.
You notice that the copies you print have a dark shadow across the entire page but otherwise seems to print fine.
You have a problem with the toner cartridge.
Toner copier/printers print by transfering toner to a drum using electrostatic electricity and depositing it on the paper. Once on the paper it is set using a heating element or fuser.
Over time the brush which contains the toner in the cartridge and the scraper which scrapes off any excess toner, or toner which is left on the drum, wears and allows extra toner to remain on the drum, which gives the dark shading I mentioned.
To compound the problem these days the cartridges are recycled and obviously at some point the scraper will wear out and you may be the unlucky person who purchased the unit. If that is the case I suggest returning the unit to the store of purchase and exchanging it or getting your money back. Most reputable stores do not have a problem doing this.
New cartridges would run out of toner prior to this problem developing. They have been designed to last slightly longer than the amount of toner which is in them. When recycled and refilled the problems start.
Recycled and refilled cartridges are not always marked as such so there is no way to tell if yours is a recycled unit.
Another problem these days is the drums are being made out of plastic instead of metal. They wear faster and die sooner and cannot be recycled successfully as often. Once they have a scratch they will never print a nice copy again.
If yours is plastic that is probably the problem. No matter which problem you have, worn scraper or plastic worn out toner cartridge, the solution is the same.
You need to purchase and install a new toner cartridge.
Thanks for using FixYa and for the great rating.
on Dec 09, 2010 | Printers & Copiers
Toner exhausted
Time to buy one or more new toners. Software supplied with the printer will usually tell you which toner colour needs replacing and also a part number to aid ordering the right one, as for changing it. Check the printers manual or the manufacturers web ste fir detsils.
Dec 08, 2013 | Printers & Copiers
What you mean by 'toner low' in cannon MF4320-4350 ??
Toner Low message appears on the printer display screen when the toner cartridge is exhausted and there is no more toner powder left in the cartridge. At this point, you need to replace the toner cartridge in order to print. It is recommended that you buy an original toner cartridge to replace it because original cartridge will give you better results
Hope it helps! Good Luck! Thanks for using Fixya!
Sep 23, 2011 | Printers & Copiers
End of toner life on Brother HL-2140
What you should do is look at the short sides of the toner. You will notice a clear round piece with tabs sticking up. What you need to do is color the inner part of the circle with a sharpie. This should give you another 100 prints or so. After you've exhausted that option, cover the spot a few times with electrical tape. What this is doing is block the "low toner" laser from shooting through these open spaces, tricking it into thinking it is full. Be sure to be observant; when the paper begins to look 'dirty' it is REALLY time to replace the cartridge. I've gotten up to 2,000 prints extra by doing this!! Good luck!
May 13, 2010 | Brother HL-2040 Laser Printer
Why do my images rub off the copy easily? I have a brother mfc-8860dn and I have the same problem. I notice that on bond paper (envelopes and letters I mail out) when they come back all the toner is...
This machine truly isn't designed for printing very high volumes of heavier bonds/envelopes. I think what you will notice is if you only print a few sheets at a time that the toner will be better fused than if you print many sheets.( you can check /test yourslef) The heavier bonds will quickly and dramatically reduce the temperature of the fuser and it can't recover on long runs of heavy paper.
Low temperature= poor fusing
Apr 11, 2009 | Brother MFC-8860DN Printer
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
Mar 25, 2009 | Samsung SCX-4300 Monochrome Laser...
HP LaserJet 1100A unwanted toner marks on face of print
check this link,
either fuser or print drum. to verify , start print job, open door before finnished and see if marks appear before or after fuser. Before paper gets to fuser toner ink will smudge.
Feb 15, 2009 | HP LaserJet 1100a Printer
Hp2820 noise when printing
Try substituting a new imaging drum. The problem may be a bad bearing.
Oct 09, 2008 | HP LaserJet 2820 Printer
Oki C3200n Says Order K Toner after install
Two possible problems:
1. You actually got a partially empty new toner. This has happened to me once.
2. The sensor on the printer is dirty and not seeing the toner. With the toner there is a little wipe that says it is for cleaning the LED. There is an LED sensor that "reads" the presence of the toner. If this is dirty it will think there is no toner cartridge.
Jul 09, 2008 | OKI C3200n Led Printer
Dell 1700n Laser Printer Logo
203 people viewed this question
Top Dell Printers & Copiers Experts
Prashant  Sharma
Prashant Sharma
Rick Johnson
Rick Johnson
Level 1 Expert
Are you a Dell Printer and Copier Expert? Answer questions, earn points and help others
