Question about Dritz Chalk Wheel Kit
Cannot figure out how to load chalk into the chalk wheel
Need additional instructions with photo reference, step by step
HP Photosmart 3210 service & repair manual sought
There is NO technical information available for any HP inkjet models, not for anybody, even service centers.. HP offers exchange only.
Apr 02, 2014 | HP Photosmart 3210 All-in-One Printer...
Steering is noisy at slow speeds when turning
This car is essentailly the same as the Lincoln LS & T-Bird.
Here is their solution.
please rate if this helps you. Thanks.
ISSUE: Some 2003-2005 Thunderbird, Aviator, and Lincoln LS vehicles may exhibit steering gear squeak when turning the steering wheel, especially during low speed parking maneuvers. The noise may sound like it is coming from the steering column area and may be felt as a roughness in the steering wheel, while turning.
ACTION: Refer to the following Service Procedure.
SERVICE PROCEDURE NOTE: USE ONLY THE FLUID AND ADDITIVE SPECIFIED IN THIS ARTICLE. USING ANY OTHER FLUIDS OR ADDITIVES MAY RESULT IN SEAL DETERIORATION AND LEAKS.
  1. Open the hood and remove the power steering reservoir cap.
  2. Raise the vehicle on a hoist. Refer to Workshop Manual, Section 100-00.
  3. With engine off, drain power steering fluid by disconnecting steering lines and clamp plate from steering gear. Refer to Steering Gear Removal and Installation procedure in Workshop Manual, Section 211-00, follow only the steps required to disconnect the steering lines.
  4. Turn steering wheel lock-to-lock to drain fluid completely.
  5. Reconnect steering lines and clamp plate to steering gear. Torque retainer to 15 N-m (11 lb-ft) for Lincoln LS and Thunderbird, torque to 25 N-m (18 lb-ft) for Aviator.
  6. Lower vehicle.
  7. In a clean container mix 50 ml (10 teaspoons or 1.7 oz.) of Motorcraft Additive Friction Modifier, Part Number XL-3, with 50 ml of Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid, Part Number XT-2-QDX. NOTE: DO NOT PERFORM STEPS 8 AND 9 ON A HOT VEHICLE.
  8. Pour the above mixture into the power steering reservoir.
  9. Top off (fill) the power steering system with Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid, Part Number XT-2-QDX and reinstall the power steering reservoir cap.
  10. Raise vehicle on hoist enough so the front wheels are off the ground and can be turned from lock-to-lock.
  11. Start the engine and keep it at idle. Remain inside of the vehicle.
  12. Slowly cycle the steering wheel from lock-to-lock for two (2) minutes.
  13. Quickly and forcefully turn the steering wheel in one direction to full lock (either side). Bounce the steering wheel on/off of full lock twenty (20) times forcefully. NOTE: IT IS CRITICAL THAT THE STEERING WHEEL IS TURNED QUICKLY AND FORCEFULLY IN ORDER TO CREATE A PRESSURE SPIKE IN THE POWER STEERING SYSTEM.
  14. Repeat Step 13 in the other direction. Return the steering wheel to on center position.
  15. Slowly turn steering wheel to full lock in one direction (either direction) to achieve maximum pump pressure. Hold at full lock for one (1) second, then turn the steering wheel back 90 degrees as quickly as possible. Repeat this procedure twenty (20) times. NOTE: DO NOT HOLD THE STEERING WHEEL AGAINST THE STOPS FOR MORE THAN THREE TO FIVE (3-5) SECONDS AT A TIME. DAMAGE TO THE POWER STEERING PUMP MAY OCCUR.
  16. Repeat Step 15 in the other direction.
  17. Cycle the steering wheel slowly for 1 minute to confirm that the squeak is corrected and return vehicle to the customer. NOTE: IF THE SQUEAK CONTINUES, REPEAT STEPS 13-16 ONE ADDITIONAL TIME. IF THE SQUEAK IS STILL NOT CORRECTED PROCEED TO STEP 18.
  18. If the squeak is still present after performing Step 17, replace the steering gear. Refer to Workshop Manual, Section 211-00 for removal and installation procedures.
PART NUMBER PART NAME XL-3 Motorcraft Additive Friction Modifier XT-2-QDX Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid 5W4Z-3504-A Steering Gear (LS) 5W6Z-3504-A Steering Gear (Thunderbird) 5C5Z-3504-AA Steering Gear (Aviator)
Aug 15, 2011 | 2003 Jaguar X-Type
Manuel has 6 boxes of chalk having 100 pieces each and 7 boxes of colored chalk having 20 pieces each.he shared equally the colored chalk among his 4 friends. how many chalk does manuel have?
If manuel is sharing the box with 4 friends and himself that is 5 people.
First multiple 6 times 100= 600 chalks/ 5 people. so 120 chalks per person.
Then for colored chalks. 7*20= 140 chalks/ 5 people. so 28 colored chalks each.
In total manuel and each of his friends have 148 chalks each.
Jun 15, 2011 | Computers & Internet
On my Whirlpool Duet Washer the front door bellow is slightly torn and the door won't seal and thus leaks water. I can get the part, but where do I find a diagram or instructions on how to change it?...
The following link explains step-by-step how to change a door bellow on a Whirlpool frontloader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you need some illustrated parts drawings to refer to for additional assistance, refer to the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
If you need any further guidance, please let me know. I hope this helps you.
Jun 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I just bought a Minolta maxxum QTsi from a lady and it had no manual with it, I can't figure out how to load the film. Can you take me step by step on how to load the film and how the camera works when...
Hi, I've found the instruction manual online for you, http://www.mediacollege.com/equipment/manual/konica-minolta/camera/maxxum-qtsi.pdf that way you have it for future reference. For loading film you open up the back of the camera and make sure that the end of the roll of film is aligned with a red mark and then you close the back. For taking pictures you press the shutter button half way in order for it to focus, when the image you want is framed you press the shutter button the entire way and it'll take the photo.
May 13, 2011 | Minolta Maxxum QTsi 35mm SLR Camera
Missing knex 6 foot ferris wheel instructions. can you please send them to me?
Here are the instructions from Instructables.com You can join the site for free and download a PDF version of the instructions from there, or just view them step by step.
http://www.instructables.com/id/Knex-6-foot-ferris-wheel-Full-Instructions/
May 08, 2011 | Toys
We seem to have lost the instructions--how much water needs to be added?
The instructions list these steps:
1. Fill the bottle with 5 capfuls of water
2. Recap the bottle tightly
3. Shake it up, until the powder and water are completely mixed
4. Pour into mold until shape is filled. Avoid overfilling. Pour excess into another shape to create 2-color chalk!
5. Let it set for 10-20 minutes
6. Once the chalk has hardened completely, pop it out
7. Try it out
Have fun!
Jan 14, 2011 | Crayola Chalk Maker Critter
I dont have the disc to down load pics from my camera
Hello
At the link below you will be directed to a page which will give you step by step instructions on how to transfer photos from your camera to your computer without using any additional software.
Click HERE to navigate to link.
Please feel free to let me know if you need any further assistance.
Kind regards
Lock123
Dec 12, 2010 | Oregon Scientific DS6618 Digital Camera
How do i load pictures from camera to computer
Hello
Kind regards
Lock123
Dec 10, 2010 | Samsung S860 Digital Camera
How do I calculate wheel size for my bike. 25 inch wheel without tire for example
There's a size chart on page 15 of the manual that has great instructions for measuring and entering the wheel size.
You can get the manual from Sigma's website at this link.
Method "B" is the most accurate way -- make a chalk mark on the tire and stand the bike up next to a wall with the chalk mark at the bottom.
Have a friend make a chalk mark on the ground at that point.
WITH YOUR FULL WEIGHT ON THE BIKE, move forward for one rotation of the wheel -- until the chalk mark is on the bottom again. Do this as straight-line as you can.
Have your friend make another mark on the ground at this point, and measure the line between the two points on the ground.
This is the wheel circumference, and if you do this with normal tire inflation and with your full weight on the bike, it's the most accurate way to calibrate your cyclocomputer.
If this helps, please be sure to hit the "thumbs up" for me.
If not, of if you have questions, use "add comment" to post back here, and I'll do my best to get you going.
May 20, 2010 | Sigma Sport BC1106 Dts Wireless Bike...
Dritz Chalk Wheel Kit Logo
42 people viewed this question
Top Dritz Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Dritz Hand Tool Expert? Answer questions, earn points and help others
