Question about Dell Studio One 19 PC Desktop
My dell studio screen turns black after 2 seconds
  • 19 Answers
SOURCE: Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Posted on May 16, 2009
benwabnick
  • 2404 Answers
SOURCE: Dell Studio 17 laptop screen stays black
Awesome, I'm glad reseating the lcd cables did the job. Its crazy how the littlest things can cause such a mess sometimes. Your very welcome and when you get the chance, please rate my solution. Hope your weekend is a great one!!
Ben
  • 3940 Answers
SOURCE: Screen is black after sleep/hib, Dell studio XPS, Vista.
Hibernate problems are generally associated with the Video Driver. Suggestions:
  1. Update the BIOS to the current release. Here is the latest for the 1645. http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=STUDIOXPS1645&os=WV64&osl=en&catid=&impid=
  2. Update the video driver.
Posted on Dec 21, 2009
budmrtn
  • 11361 Answers
SOURCE: my dell monitor turns on for 2 seconds then goes
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdreapir.us
Posted on May 16, 2010
ghost2233
  • 3606 Answers
SOURCE: I have a dell 1735 studio laptop. When I turn it on I have only a black screen. I'am able to do a diagnostic and I am getting an error code 2000-0146, but I can't get past the black screen.
Hello here is some info about your dell:
http://en.community.dell.com/support-forums/desktop/f/3514/p/19342733/19736103.aspx#19736103
Error 0146 indicates a failed/failing hard drive or bad drive sector.
Basically, this means your hard drive will need to be replaced.
Even more here:
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=cmu&k=error+code+2000-0146&rpp=12&p=1&rf=all&nk=f&ira=False&~srd=False&ipsys=False&advsrch=False
Here is the home page:
http://www.dell.com/support/drivers/us/en/19/Product/studio-1735
A computer repair shop can help you with recover your data if is not damaged by the bad sectors.
I recomend to change the system to windows 7 (32bit) because the support for vista is out by this year.
Good luck
Posted on Nov 15, 2012
Dell Studio one Powers on then screen goes black
Either CPU or GPU is getting too heated up.. Try to clean and apply thermal paste on your CPU GPU chips.. Usually cpu gets heated up when you've a weak SMPS output.. Check that too with known good one power unit.
Mar 27, 2013 | Dell Studio One 19 PC Desktop
Even more here:
Good luck
Nov 12, 2012 | Dell Studio 17 Laptop
Dell STUDIO 1537 black screen on first boot up ??
The inverter maybe faulty, it supplies high voltage to the CCFL lamp and would cause the screen to be black.
Since it was just repaired, I suggest you return it to Dell to have it repaired under warranty.
May 09, 2012 | Dell Studio 1537 Notebook
Black screen on my Dell Laptop
Same problem as mine. Its a loose connection, sometimes it may come right and other times it would go back to this state. You could continue using the second screen, or otherwise depending on your budget get you laptop screen changed
Dec 09, 2011 | Dell Studio XPS 13 Laptop Computer (Intel...
Hi there! i have dell 1537 studio and the screen is all black now. the laptop does not boot and the volume light button flashes for few secs after i turn the power button on and the laptop shuts down...
Hardware failure, most likely in the motherboard. Take the laptop to a repair shop for an in-depth testing. Beware, the repair will be expensive.
May 11, 2011 | Dell Studio 1535 Notebook
DELL STUDIO 1737, WITH WIN 7, WILL REBOOT AT SHUTDOWN.\r\nIT SHUTSDOWN FOR ABOUT 3 SECONDS, THEN REBOOTS TO A BLACK SCREEN WITH: "WINDOWS DID NOT SHUT DOWN PROPERLY, SELECT ONE OF THE FOLLOWING:" Start...
operating system issue try to repair os or make a clean new os installation (make backup before you go for clean instillation...
best try to repair and restore....
thanks
Aug 18, 2017 | Dell Studio 1737 Laptop
Dec 19, 2009 | Dell Studio XPS 16 Notebook
Ben
May 15, 2009 | Dell Studio 17 Laptop
Dell Studio One 19  PC Desktop Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
