Question about Boating
Motor dies when put into gear or shift
Motor was running good then all of a sudden won't idle,dies when shifting still runs ood at high speed
  • 3567 Answers
SOURCE: i have a 1990 honda 300 four trax 2x4 and a nice bike good shape
Good news > save your money on the clutch. Bad news > Invest it in new shift forks. What you describe is a standard symptom of bent shift forks. Sorry to be the one to tell you this.
Posted on Apr 11, 2009
  • 186 Answers
SOURCE: 95 saturn sc1 all of a sudden had engine light on
You either have a bad engine coolant temp sensor & connector.Located under upper radiator hose at cylinder head Yellow & black wire.Original sensor is ceramic & replacement will be brass from saturn.Also you may check for vacuum leaks at PCV hose & valve.Hope this helps
Posted on May 16, 2009
  • 35 Answers
SOURCE: My H2 2003 hard or take time to shift when running to 35+ MPH
check your tranny fluid and filter. you may have a clog some where or could be low on tranny fluid.
Posted on Jul 25, 2009
  • 62 Answers
SOURCE: runs first gear to max rpms before shifting.
You probably have a bad governor pressure sensor and solenoid.The pressure sensor is what normally goes bad ,but from vast experience,i replace both of them together and change fluid and filter.
Posted on Aug 09, 2009
  • 102 Answers
SOURCE: I have a 1990 Chevy 1500 SS truck with a 454ci. that has an idle
The problem you are describing, is due to the mass airflow sensor, being out of spec. A new one will surely correct, the said problem.Also try a new Idle air compansator switch,in combination with the before described mass air flow sensor. I hope this help's.
Posted on Mar 06, 2010
125cc Kawasaki dirt bike, cranks on first kick, idles but won't run in any gear, doesn't die out but doesn't seem to engage gear, possible problems?
Does it jerk forward when you put it into gear and die? Or you put it into gear and the bike doesn't move when you let the clutch out? Badly adjusted clutch in both cases. Worst case, you need new clutch plates and springs.
Mar 25, 2017 | kawasaki Motorcycles
What does it mean when the car jerks when you put it into gear?
The car pulls suddenly hard in forward or reverse direction at the moment you change gears.
Jul 03, 2014 | 2007 Pontiac G6
Wont shift from nutral in to gear while running
Often, it mean that the clutch stay engage.
Now the question can be, is the idle to high for the clutch to disengage while at idle? you might try to reduce the idle speed by turning eather the nob on carburator or the ajustement on the cable.
then if the idle is very low and the clutch still engage (that is why you can not shift) you migh want to check at the clutch and see if it is not stuck.
Nov 07, 2013 | RTO 125cc Full Size Adult Quad ATV
1995 Ford Bronco engine dies when shifted into drive but runs in reverse or 1st gear
Could be fuel filter,air filter,tune up,wires,coils.low idle too low.
Jun 13, 2013 | 1995 Ford Bronco
92 SL1 won't idle-wants to die without pushing gas-just put in new plugs
Remove, clean and inspect the idle control valve on the throttle body. These tend to clog up over time, or the stepper motor fails. Check this before anything else.
Nov 07, 2012 | Cars & Trucks
Shuddering at idle in a 2002 mercury cougar
1st to second sounds like a forced shift i would check the 1-2 shift solenoid inside the transmission and make sure the speed sensors are all in good working order, clean and apply electro grease to plugs on the transmission , as for the idle problem it could be many things from sensors for the engine to a torque converter lockup solenoid need more info is the check engine light on? you said it shudders is it missing or has a surging idle ( high and low) does it die when it goes low idle or stay running
Oct 15, 2012 | Mercury Cougar Cars & Trucks
Motor dies when shifting into 1st gear from idle
Hi and welcome to the site,
Initially, check, clean, bypass or replace the sidestand switch.
Good luck and thank you for asking.
Jul 26, 2010 | 1995 Yamaha FZR 600
Boating Logo
415 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
