Samsung DVD-R155 Logo
A
Anonymous Posted on Mar 17, 2014
Want play dvd says this disc want play - Samsung DVD-R155
2answers
Movie DVD is not played. No disc message is coming?
Try to play dvd on other computer or laptop if dvd is playing their fine then it is problem with your dvd rom lance. also try to play other movie dvd on same dvd rom If other dvd play fine then their is problem with movie dvd.
2answers
4helpful
My dvd player plays dvd discs ok. but when i use dvd burned on my computer shows no disc.the same disc plays fine on my computer
Some DVD and Blu-Ray players will not play a burned disc until it has been finalized. Finalize the disc on your computer then see if it will play. (Finaalizing a disc means it can no longer be recorded to, by the way.)
2answers
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
4answers
Is the philips dvd player dvp3982 ale to play blu=ray disks?
DVD players cannot play Blu-Ray discs. Most Blu-Ray players have DVD support, which means they can play DVDs as well as Blu-Ray. Unfortunately, the DVP3982 is not a DVD player, not a Blu-ray player, therefore it cannot support this format.
5answers
Plays dvds fine but won't play blu ray
DVD players can't play Blu-Ray . You need a Blu-Ray player for that .
4helpful
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
TV says WRONG DISC TYPE
is the dvd a store bought disc or a burnt dvd? If the disc is a store bought disc I unfortunately can't help you. But if the dvd you are trying to play is burned from dvd burner you are most likely using the wrong type of burnable dvd. There are two types of dvd's you can burn, DVD-R and DVD+R. You need to make sure which one you dvd player can play, some play one or the other, some play both. I have also heard of some older ones that can't play any type of burned disc. Hope that helps Peter
1helpful
3answers
Will not play any DVD
I may have bad news for you. Here's my story with the PVD4744S.
I watched over an hour of a DVD-video disc one night, no problems. The next night, I played only the intro; then the DVD player gave a message, "This type of disc cannot be played. Please insert another disc." Thereafter, I couldn't play any of several DVDs.
The manual gives little help:
http://service.us.panasonic.com/OPERMANPDF/PVD4744.PDF
My disappointment is exacerbated by the declining availability of DVD/VHS players with an RF modulator. Maybe Panasonic should create a repair kit for aging devices.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
