Question about Krups ProAroma 453-42 Coffee Maker
The display reads CALC.
What does it mean when the display reads CALC?
Cannister leaks all the water out
Posted on Dec 14, 2007
I have a Krups model FME4 and it means that you should descale the machine. Here's a link to the use and care instructions for my model, I assume it would be the same for yours.{EC10140D-AA43-4DCA-8D3A-A5A4823D9E52}&SelectedProdRef=FME4
My problem is that CALC continues to display even after I've descaled several times. Good luck with yours.
Posted on Oct 30, 2007
How to turn on diagnostic on casio fx cg 10
You got yourself a prizm, learn to use it and forget about the TI84 Plus. The DiagnosticsON is a command of the TI8 84 plus. You can activate it for statistics or deactivate it. For the Casios, the determination coefficient or the correlation factors are always displayed. If the regression model you are using has a correlation coefficient it will be displayed on the same screen the statistical values are displayed.
Please read your manual, it will help you a lot.
Sep 25, 2012 | Casio Prizm Fx-cg-10-l-ih Graphing...
Whats the short cut to get to calc screen
If by calc screen you mean HOME you usually get back to it whenever you interrupt the execution of a command. You can also go to HOME by pressing RIGHT SHIFT (Cyan) key then the appostrophe (below MTH). That returns you to the HOME directory. To set the menus to the default ones, press MTH
Apr 19, 2012 | HP 48gx Calculator
What do you do when it says calc. on the display?
Calc is indicating that it's time to descale the lime build up inside your coffee maker. Most machines are easily cleaned by running a solution of 4 parts water to 1 part vinegar. Run this solution through a regular coffee cycle (no coffee). After running this solution, you may want to run straight water once more to ensure there's no vinegar aftertaste. Your machine will now be clean and the CALC message should disappear. If not, post back with the Model # of your Krups coffee maker for further instructions. Some machines have a Descale or Self Cleaning option built into them.
Apr 24, 2011 | Krups Coffee Makers & Espresso Machines
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
Hi My spy calc on my iPhone, will not open.. I'm using the correct password. Is there anyway of getting in? Changing password? Recovering files?
I cannot get into mine either. I'm beginning to wonder if I have the correct password. Is there any way to reset?
Jan 16, 2011 | Agilitech Spy Calc Free
I have requirq a calculator for adding something
Hello, Go to start, in the search box, type calc and press enter, a calculator will display on your screen or click on start>run,in the run box type in calc and pressenter, your will see the calculator on the screen. regards
Dec 08, 2010 | Computers & Internet
Can i do statistics on the casio fx-115 es? and how can i use it?
Yes and here is how to do 1-var statistics and 2-var statistics. Please read the whole post. I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Nov 06, 2010 | Casio FX-115ES Scientific Calculator
I have by mistake deleted calculator from accessories. How do I get it back?
The program is located in C:\Windows\System32\calc.exe Browse to the location select the file right click >>> create shortcut Now,click on and hold to drag the shortcut to your start button, dont let it go keep dragging it to Program files >>> Accessories then drop it in there by letting the mouse button go.
Aug 29, 2010 | Microsoft Windows XP Home Edition
Using the CFX9850G, how do you get to do normal distribution with lower,upper, mean and standard deviation? I can't find the menu to get to that function.
Press Menu to get the icons displayed. Highlight STAT and press EXE.
If you want to perform statistical calculations, press the F2:Calc key and choose the Type of stats :1-Var, 2-Var, and Regressions.
If you want to use the normal distribution, press F5:DIST then F1:NORM.
Feb 15, 2010 | Casio CFX-9850G Plus Calculator
Ti-83 plus silver edition. calc won't turn on.
Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
Hope it helps.
Oct 09, 2009 | Texas Instruments TI-83 Plus Silver...
Krups ProAroma 453-42 Coffee Maker Logo
719 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
