Question about Sport & Outdoor - Others
What is the use of the fttn networke - Sport & Outdoor - Others
Names
Personal Area Network
Local Area Network
Metropolitan Area Network
Wide Area Network
Don't forget about SAN, CAN, DAN, and WLAN.
Storage Area Network. Also known as Server Area Network, Storage Area Network, and Small Area Network.
Campus Area Network. Also known as Controller Area Network, or Cluster Area Network.
Desk Area Network
Wireless Area Network
http://en.wikipedia.org/wiki/Computer_network#Scale
http://en.wikipedia.org/wiki/Local_area_network
Regards,
joecoolvette
May 11, 2013 | Computers & Internet
Ipod wi fi conection
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
Dec 27, 2010 | Cisco Linksys Wirelessn Router Black...
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
Virgin has installed. D link wireless router (home address) I have 2 laptop xp window vista and pc upstair they detect the vg 50Mb broadband but can not connect ! When I go with my 2 lap top elsewhere I...
1.
2.
3.
• To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
• To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
4.
• To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
Important
• If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-300 Wireless Router
My acer one netbook is stuck on aquiring network address
Hi Boyer,
I got your issue, Since it says accquiring network address.
If Your comp if its win 7 Operating system
1. Click on start go to control panel--> go to network and internet and then click on network and sharing centre
2. In network and sharing centre in the left hand side click on manage wireless network
3. In manage wireless network, you can see the networks which you have connected before , right click on the network name and select remove network. In the same way remove each one of them, the screen should me empty. there should be 0 items.
4. Then go back to network and sharing centre and click on connect to a network, you can see your network name , click on the network and click on connect to connect to the network.
If Your comp if its win Vista Operating system
If Your comp if its win XP Operating system
1. Click on start go to control panel--> go to network and internet connections
2. Then go to network connections
3: You can see wireless network connection , right click on it and go to properties and go to the wireless networks tab
4. In wireless network tab, under preferred networks, if you see any network , remove it and then push ok
5. Then right click on wireless network connection and go to view available wireless networks
6. here you can see the network and you can connect with your password.
Please try this, im sure this will work
Thanks & Regards,
Prema
Oct 09, 2010 | Computers & Internet
I have got a Toshiba Satelite L40 - 17U, Window XP and i can't connect it my laptop to my wireless modern. i also would like to clean it or maight say erase everything and install everything...
Hi Dacosta,
I got your issue that you have trouble connecting with ,
Thanks & Regards,
Prema
Oct 06, 2010 | Toshiba Computers & Internet
Having trouble connecting to an AT&T 2-Wire 2701 HGB Wireless Router (DSL).
Hi John,
I got your issue that you have trouble connecting with the At &t wireless modem ,
Thanks & Regards,
Prema
Oct 06, 2010 | Computers & Internet
My samsung E250i network problem no network showing on display.as well no network found
Jul 06, 2010 | Lands Phones
I can't get it to work.
To view the wireless network connection dialog box, follow these steps:
  1. Click Start, Run, and type ncpa.cpl, and then click Ok.
  2. Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
  3. Click the Wireless Networks tab.
  4. Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
Apr 28, 2009 | Airlink AWLH3026T 802.11g/b Wireless...
2 Network ID on one PC
What operating system are you using? If it's Windows XP, go to Control Panel, Networking, right-click on the first network adapter, Properties, then select TCP/IP, Properties and enter the appropriate network settings for the first network. Repeat for the second network adapter and second network.
Mar 11, 2009 | Computers & Internet
Sport & Outdoor - Others Logo
29 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
